Old 01-14-2021, 12:22 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Slow starting cars
We where working on one of our Z/28 yesterday, we are adding a live mirror to the old 5th gen out of the 6gen cars with a mirror out of a truck ( fits the 5th gen) but at the same time i was looking at why this car (has headers) does not like to start.
We added a ground strap from the starter to the side of the body, and that helped but it still hung up after one turn then will kick in and start, that was on a full charged battery.
so now we where looking at the battery side of the problem, and what we found is the ground strap from GM, that goes from the battery to the body is nice looking but that's all, its covered in rubber and all you get is the little point of contact, where the bolt goes true for ground, so we added a second ground strap like the one we did up front.
All i can say is its better then when it was new car, will post videos next week of before and after, you can do this in 15 min, one last thing this is the OEM battery so its 6 going on 7 years old.
Old 01-14-2021, 12:30 PM   #2
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
Awesome, thanks!
AustexaSS is offline   Reply With Quote
Old 01-14-2021, 12:37 PM   #3
Coz3z3
Drives: 2015 Z/28, 2015 1LE
When you added the second one in the back, did you connect it from the battery to the body? Or from the existing bolt to another point on the body? Or replace the whole GM ground strap? Thanks!
Coz3z3 is offline   Reply With Quote
Old 01-14-2021, 01:54 PM   #4
2SSRS@Gen5diy
Like i said we will post videos soon, have to go test drive that Z/28 for the live mirror now.
Old 01-14-2021, 03:37 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So you have a mirror upgrade for my 5th Gen!?!?
Orange Krush II
Old 01-14-2021, 03:40 PM   #6
Fast.Freddie
2015 Z/28 #48
Drives: 2015 Z/28 #48
Subscribed! Live mirror would be killer !
Fast.Freddie is offline   Reply With Quote
Old 01-14-2021, 06:41 PM   #7
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
What is a ‘live mirror’?
69L48Z27 is offline   Reply With Quote
Old 01-14-2021, 07:53 PM   #8
Coz3z3
I think it’s the backup mirror but instead of the camera taking a portion of the mirror, it looks to turn the whole mirror to a screen that displays the rear camera. Also it looks like it can be turned on and off whenever desired. I just would hate to get rid of the frameless look our mirrors have
Old 01-14-2021, 08:02 PM   #9
69L48Z27
69L48Z27's Avatar
Ah, got it. The new C8 have that. Rear camera image is the entire mirror all the time.
Thx!
Old 01-19-2021, 12:16 PM   #10
young51
Drives: 2015 z/28
Any updates on the video or the ground strap replacement pics?
thanks
young51 is offline   Reply With Quote
Old 01-19-2021, 12:57 PM   #11
saluki
Drives: 2017 Silverado
It great that the grounds helped but they are likely just a temporary fix. Its a pretty well known issue for starters to crap on cars that have long tubes. I would expect to be replacing that starter within the next year.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 01-19-2021, 02:14 PM   #12
2SSRS@Gen5diy
I have 7500Mi with long tubs on one car, and maybe 40 track days now, and it stars better then new, its still with the OEM battery (7 years old).
Old 01-19-2021, 03:22 PM   #13
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
Did you happen to take ohm readings from your factory grounding from negative battery terminal to starter vs. after you had made all the improvements?
Thanks
SIM GhostrdrZ is offline   Reply With Quote
Old 01-19-2021, 04:06 PM   #14
MontanaZ28
Drives: 2015 Z28
If you make the kit we will buy it. Both the ground cable and the mirror. Cant see shit out of a Camaro.
MontanaZ28 is offline   Reply With Quote
