02-12-2021, 07:56 AM | #1 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Need more info on the LOD
Part 1: So, it’s winter time and haven’t been driving the car, been thinking about possible upgrades after the last round was not up to expectations. I took the L99 apart and it got everything required to spin it 7000 plus, only limit is what the SBC will handle. 1 problem....at 6500 she shuts down. Done. No more power. Lol. I want to remove the next bottleneck being the stock intake and I’m having the rod mod done locally. That being said, I actually am dying inside because I want an LOD. Base price is 1500. Does it need aftermarket rails? Is anybody running it with a stock ported throttle body? Do I really need a 102? What is the realistic number to put this on my car please and thank you.
Part 2: my mods are in my signature, I set the car up initially to be a dig monster on the stock cam and it was. I will be getting a 4000 triple disk to replace the 3400 single I’ve been running. Fuel system and 2” headers are coming as well. With the LOD, should I keep the 3.91s? I’ve been mulling this over for awhile, everybody and their mom wants to roll not dig and I'm not going to say no. One thing I don’t like about the 3.91s on the auto is you use 3,4,5 for 50+ rolls. You would think it stays in the power band more with the shorter gears, but is that a deficit instead because I’m always in 5th past 120mph? I think 3.45s would be better suited for rolls but if I can spin the motor to 7-7500......? A stroker is not in the plans this year, but that’s my goal. I think the LOD would complement it nicely but let me hear y’all’s thoughts.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
02-12-2021, 08:08 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
If you are staying NA then get the gpi rod mod ported and polished. It has shown the greatest gains out of all the intakes until you are boosted and it still shined there.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
02-12-2021, 08:15 AM | #3 | |
Spend the money saved for the other goodies you are wanting (converter, headers etc).
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
02-12-2021, 08:18 AM | #4 |
02-12-2021, 08:31 AM | #5 |
I'd go bigger cam if your going to swap to a hi ram style manifold like the Holley/Edelbrock/LOD
02-12-2021, 08:54 AM | #6 |
Holley high ram seems like the king but can’t fit under stock hood sadly.
02-12-2021, 09:42 AM | #7 |
Here is mine, been on for 2 years now and love it!!!
02-12-2021, 11:22 AM | #8 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Mine as well. Over 2 years and I wouldn't change a thing....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
02-12-2021, 11:26 AM | #9 | |
The rod mod still falls of at 6700-6800 rpm. I WANT TO TURN 7000 plus!
02-12-2021, 11:29 AM | #10 |
That might be in the works, I want to remove all the bottlenecks on the night-furry until it’s the restriction and see what it does.
02-12-2021, 11:29 AM | #11 |
Clark and JEWLD what fuel rails y’all got, and what’s needed to put it on. Clark, pre stroker, I know you stated seat of the pants she took off, what did you turn it to? Jewld what are you turning to?
02-12-2021, 11:32 AM | #12 |
The Edelbrock ProFlo fits under the stock hood and is identical to the Holley in power production and RPM.
Mine has been on a year now.
02-12-2021, 11:37 AM | #13 |
True but I could’ve sworn you stated you have to trim the firewall, I’m trying to stay away from cutting anything, because if I started cutting I would gut the car and not care anymore.
02-12-2021, 11:38 AM | #14 |
Yes. That was easy
