Old 02-24-2021, 01:31 PM   #1
Bubbafire88
Bubbafire88's Avatar
Drives: 2010 Camaro ss A6 "Chief"
High flow cats?
Hi, I just bought my 2010 camaro 1ss/rs auto a little over a month ago and It came with a borla axle back, h-pipe and an afe power intake, I bought an sct tuner for a a couple weeks ago from rdp store and I’m getting some speed engineering headers and I was wondering if I should just spend the extra money on some high flow cats because I live in Texas and they don’t allow cat less cars, and I’m not sure which high flows to go with or if I should just stick with the stock cats.
Bubbafire88 is offline   Reply With Quote
Old 02-24-2021, 01:52 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
If you live in an area with emissions inspections or smog testing, then yes, get the cats.
But if there is no chance you will be tested, visual or probe, you can likely safely run catless. Just beware it will be a little louder/raspier and a LOT stinkier. Personally, I love that smell though, but it sticks to your clothes. The horsepower gain from going catless with long tubes is negligible. Some people run high flow cats just because it can clean up the exhaust sound a little bit onb long tubes, depending on your exhaust of course.
And just for the record, NO state allows removing the cats or tampering with emissions equipment. It's just a matter of enforcement and how your state handles it. I live in Florida where it's a no mans land and inspections are unheard of. If we had safety or emissions inspections we would probably lose 30%+ of the cars on the road down here.
Old 02-24-2021, 01:53 PM   #3
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Bail the stock cats for high flows for sure. Bunch of universals out there that are fine. Many in the $100 range. Does Texas actually have emissions or any kind of checks?
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 02-24-2021, 01:53 PM   #4
gunchamp
gunchamp's Avatar
Posted at the same time lol and thats where I was going. Mine are gone as its not enforced here
Old 02-24-2021, 02:44 PM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
If you need high flow cats you should get high flow cats. Smog tests will definitely rat you out, but if you don't have a sniffer test you'll fail the visual test.
If you have long tube headers you cannot utilize the stock cats. Check out Texas Speed for high flow cats. Most people who have bought Speed Engineering headers and need cats go with their high flow cats.
Side note, for those who are considering budget friendly long tubes but need high flow cats, you can't beat OBX.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 02-24-2021, 03:58 PM   #6
Avenging Orange
Avenging Orange's Avatar
If you are buying from Speed Engineering...why not get their cats too?
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 02-24-2021, 04:52 PM   #7
saluki
Drives: 2017 Silverado
texas speeds offroad pipes look just like high flow cats if he only has the visual inspection.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 02-24-2021, 06:56 PM   #8
pyroguy
pyroguy's Avatar
Drives: ABM #831
Because Speed Engineering doesn't sell cats.
Old 02-24-2021, 08:53 PM   #9
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Exactly why I went with high flows. Haven’t fired it up yet but, hoping it also will help with possible drone issues at certain rpm’s.
0stones0 is offline   Reply With Quote
Old 02-24-2021, 08:56 PM   #10
RupertPupkin
Drives: 2014 Camaro SS 1Le
Wtf... I thought Texas didn’t have emissions. If they do, then I have to rethink moving down there.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 02-24-2021, 10:01 PM   #11
Avenging Orange
How dare they make their mid pipes look amazingly like high flow cats!
https://www.speed-engineering.com/sh...ion-pipes.html
Old 02-24-2021, 10:04 PM   #12
pyroguy
pyroguy's Avatar
Drives: ABM #831
They may look like them, but they aren't. It's an attempt to let their end users fool the visual inspectors. However, a tap on them will indicate that they are hollow.
Old 02-24-2021, 10:10 PM   #13
Avenging Orange
Sneaky little devils. Whatever gets the job done.
Old 02-25-2021, 12:45 AM   #14
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Here in Texas there is no sniff test. As far as a visual inspection, they don't really do anything except plug into the obd port and as long as you don't have any codes your good USUALLY. Now if you have an exhaust that is loud as hell they might take a look but probably not likely. I would say if your worried about it I would go with cats but I'm not going to worry about it. The shop that I'm going to get to do my tune asked me if I was going to run cats or not and I told him no and alls he said was that will sound good. So I think it just depends on where you go.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
