10-29-2023, 04:07 PM | #1 |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
Elusive stabilitrak problem
I have been getting a “service stabilitrak” message for some time now on my 2018 ZL1 1LE. Usually it happens under hard acceleration. Yesterday, it came up under light acceleration, stayed illuminated longer, and I could hear my exhaust tone change as if the valves were opening and closing or the engine was surging. I did not feel any surging, though. The A/C stopped cooling for a minute or so and then it went back to normal. I drove it today and can’t get it to act up again. No codes were set. I have heard that throttle bodies sometimes cause issues like this? Car is cammed and tuned but throttle body is stock. I don’t want to go buying parts without some idea what it could be.
10-30-2023, 09:55 AM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Check your battery. Most of the problems when you see that message is the battery going bad.
Cars these days are dependant on a good operating battery. So I'd start with that first. |
10-30-2023, 01:07 PM | #3 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
If the car has headers, check the pass side harness for burns.
Put the battery on a tender for 48hrs. If problems persist, find the best automotive electrician in your area. |
11-16-2023, 06:05 PM | #4 |
Found some codes in the BCM, cleared them and then went for a drive to get the message to come up again. Checked for codes and found these. I’m guessing it could be the voltage regulator. Might need to replace the alternator. Wish I knew for sure, that job is a pain. Might not be so bad with the BMR motor mounts.
11-20-2023, 04:50 PM | #5 | |
376 cubic inches of fun
12-03-2023, 09:39 AM | #6 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
Good advice. The 5th Gens are even worse. I speak from experience.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
12-06-2023, 07:38 PM | #7 |
Update - it was not the battery, it was the alternator. I’ve had battery issues in a Gen 6 before, even from a brand new Optima battery which I found aren’t what they used to be. I agree there are a lot of battery related issues, but it turned out that this wasn’t one of them.
I found the problem by reading the BCM codes indicating high voltage, and my service manual indicated that the codes meant a problem with the charging system. Battery voltage on my Aeroforce gauge was bouncing all over and going as high as 15.5 volts. After getting 2 damage alternators from GM I finally got a good one and installed it. The packaging they put it in is totally inadequate. Working great now. |
12-06-2023, 07:45 PM | #8 | |
PKG4U
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
12-06-2023, 08:08 PM | #9 | |
The first alternator was dropped on the pulley and wouldn’t turn. Second one was broken in the box (pic below). As far as installing, I was able to do it all on a lift from the bottom once the belt was off. Having the BMR motor mounts surely made it easier. Had to remove the shear plate, power steering rack, sway bar, and slightly raise the motor on the passenger side to do it. |
12-06-2023, 09:23 PM | #10 | |
PKG4U
12-06-2023, 11:33 PM | #11 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
12-07-2023, 11:14 AM | #12 | |
These alternators, I believe, are on a charge as needed system or whatever you want to call it. Where is it isn't needed then the current drops and when is needed it jumps up. Anywhere from 11 to 18 volts. It's crazy how things are with shipping these days. Only in the past 2 years have I started to get broken items or incorrect items. Just document everything when you open it and call right away to get it taken care of. |
12-07-2023, 05:52 PM | #13 | |
