12-22-2022, 06:47 PM | #1 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
305/35/20 on 10 inch wheel
Hey guys, Well I am getting 3.73 gears put in in March at GPI and I want lighter wheels that are as near as I can get to stock diameter. I wanted to stay with 20s as I don't want to get to much smaller in the diameter and I already have new 245/45/20 tires up front.
So here is what I want to run, 305/35/20 General GMAX RS on TSW Nurburgring on a 20x10 wheel in the rear and then 20X9 wheel up front for the 245/45/20s and then when those wear out I will probably go to a wider tire up front. General tire says they recommended wheel width is 10-12 inch wheel and 305 is a 28.4 diameter so it won't be a large difference from the front diameter at 28.7 and should work. My only concern is a 10inch wide wheel enough for the 305 on the back and will it have any problems with over steer in anyway with that big of a difference between the 245 in front and 305 in the back for now? Thanks |
12-23-2022, 09:43 PM | #2 |
Yes, 305/35's will fit nicely on a 20x10 wheel. However, the 245/45's on a 20x9 might be stretching a little...9 is probably at the max wheel width. If your rear tires (assuming they are the stock 275/40's) are still in good shape, you could swap them onto the new 20x9's.
Just for conversation sake, I'm currently running 305/35's on 20x10's in the rear and 275/40 on 20x9's up front. Unfortunately, I never tried driving with the stock fronts and the 305's, so I'm not sure if oversteer will be an issue at 25% difference in width. |
01-21-2023, 08:18 AM | #3 | |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
01-21-2023, 02:00 PM | #4 |
Back when I had 10 inch wide rears I ran 315/35's for many years with no issues, and 275's on the front on 9 inch wheels. Here is a pic.
Thread Tools | |
