12-31-2022, 02:35 AM | #1 |
Drives: 22 Camaro 2SS A10 Join Date: Jul 2010
AXDSPX-ETH1 Camaro with BOSE 2019-Up
So after lurking here for months looking for a 2019+ Bose integration/bypass solution, I stumbled upon the AXDSPX-ETH1 in the axxess website which seems to tick off most boxes. It seems nobody here has mentioned it yet, so I figured I would ask the audiophile experts in this forum what your opinion on the matter is. I am no expert, I have however installed a few car stereos in my time, as well as a BOSE integration harness in my TBSS. Is this something I could tackle on my own? Would I need any other toy like twk's and the fix's and what have you?!
I have attached the PDF and it looks pretty straightforward. Thoughts?
2022 Camaro 2SS A10
2007 Trailblazer SS |
12-31-2022, 07:27 AM | #2 |
Their vehicle fit guide says it will work. For that price, I'd probably go with the NAV-TV M650-GM which is highly recommended by others here.
https://navtv.com/products/NTV-KIT838/m650-gm.html Personally, I went with the Sub Thump 2016-2023 Camaro With BOSE Plug N Play T-Harness With ANC Defeat Harness Kit, and then go with a line out converter matched to your output channel needs.
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
12-31-2022, 02:52 PM | #3 | |
2022 Camaro 2SS A10
2007 Trailblazer SS Last edited by DualSS; 12-31-2022 at 03:04 PM. |
12-31-2022, 04:09 PM | #4 |
The nav-tv website shows that it's compatible with 2019, so I bet it would work with all 2019+.
Check this thread, it might help with the direction you want to go. https://www.camaro6.com/forums/showthread.php?t=561714
12-31-2022, 06:22 PM | #5 | |
2022 Camaro 2SS A10
12-31-2022, 08:23 PM | #6 |
Here's how the harness connects to the Bose amp. The red circle is where the sub thump harness connects. The blue circle is where the ANC delete harness connects. You can do all the tapping & connections yourself, but these harnesses just make it a lot cleaner & neater.
12-31-2022, 08:26 PM | #7 |
Here's my finished setup, as far as the harness and line out converter. I just have a mono amp & subwoofer, so I don't use multiple channels. And then a couple of pics of my amp & sub. Nothing fancy.
01-02-2023, 12:06 AM | #8 |
That's a very nice and tidy setup you got there. How does it sound though? Does it feel like the bass overpowers the BOSE speakers? On the stereo do you just turn the bass into 0 and below? Do you have a gain dial for your sub amp near the dash?
2022 Camaro 2SS A10
01-02-2023, 08:31 AM | #9 | |
2. No, the bass is not overpowering. It was at first - I left the amp on the same setting it was on in the old Camaro. It was OBNOXIOUS. But I just turned down the gain on the amplifier, and I think I actually turned it down too much. I had the rear seat down when I adjusted it, but when I put the seat back up, it was turned down a little too low. So I think I'll turn it back up just a bit. 3. Before you hook everything up, turn everything including bass, down to 0. After you hook everything up and tune your amplifier, then you can adjust the settings at the head unit. 4. Unfortunately, I took my sub & amp out of my old Camaro the night before trading it in on the new one. I didn't take the time to remove the gain knob and all of the wiring, because it was all tucked in behind & underneath carpet and plastic trim. I kind of wish I had taken a little more time to remove wiring & the gain knob. Nobody carries the gain knob for my amp anymore, and some of the amplifier wiring was a bit expensive to replace. But to be perfectly honest, I really didn't use the gain knob all that often.
01-03-2023, 04:01 AM | #10 | |
2. I think you would use that gain knob a lot more often if you had it, at least at first. Unless you only listen to one type of music. Is your back seat normally open or closed? 3. I already have it at 0 otherwise it sounds un-natural.... 4. Sounds like your 2020 was an impulse buy. Haha
2022 Camaro 2SS A10
01-05-2023, 01:40 PM | #11 |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
I'll provide some criticism, but just to help you learn and not to dog your efforts. Thanks for sharing the pics!
In no particular order:
I'd rather see the amp mounted to the bottom of the rear deck to get it off the floor. It's totally fine to do this and there are several ways to achieve it. Main challenge is longer power/ground wires and routing them behind factory panels requires a bit more effort in the trunk. Or just remove the styrofoam holder if you're not using it and put the amp/LOC down under the floor on a custom board.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
01-05-2023, 03:12 PM | #12 | |||||||||||
01-05-2023, 09:52 PM | #13 |
My amp measures 12" x 10", I checked and it's too big to fit under the rear deck with the speakers mounted there.
01-09-2023, 11:50 PM | #14 | |
2022 Camaro 2SS A10
