09-12-2018, 02:59 AM | #1 |
INTSAGRAM: Failwish
Drives: 2019 /2SS LT1 Join Date: Jun 2015
PCM transmission cooler for the 5th gen camaro
I purchased this kit ..got it installed .only issue i had was the connection point to the radiator and the actual factory steel connect was the quick connect was wobbly..didnt feel stable connected.. i test fit both fittings.and got the same result..thats the cnc machined radiator connect and brass fittings from cooler to factory connects didnt seat well.. so i reinstalled the factory connect. The factory connects had a little yellow coller behind the snap ring push lock point..when you snaoped them in they locked in tight..the pcm kit felt wobbly and like there was no real seal connection.. before everyone and there real men use steel hose and an -6 connects comments.. i got this for ease of install and im not racing anywhere. AM I DOING THIS WHOLE CONNECTION WRONG..the factory connection had a little rubber grommet or girthier lock point being the push barb..it was a snug push and it would pop and lock into place. I marked on this barbed connection where the grommet from the gm trans hose is.. but missing on this hose from pmc https://imgur.com/a/xMsaU63
09-13-2018, 06:38 AM | #2 |
INTSAGRAM: Failwish
Well i got with mark and kelly from pcm..and after a few emails back and forth..during the day yesterday and after this post.. i came to the conclusion that maybe the wiggle was a normal thing with this kit..the last response from the pcm engineer's input was thats a normal thing for this kit as long as the seals in the radiator and inside the couplings are fresh or in good condition..
09-13-2018, 06:40 AM | #3 |
INTSAGRAM: Failwish
And after install temps after a 50mile drive and 10mile in city drive... sit a hair below 180deg..could be the 77degress temps outside playn a part in that too
09-13-2018, 10:10 AM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Is this a auto or manual cooler?
Orange Krush II
09-13-2018, 12:09 PM | #5 |
INTSAGRAM: Failwish
Auto trans
