Old 08-04-2018, 01:54 PM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Fuel pump access hole
How many of you guys done this? Worth it or not worth it? I'm concerned with there being more noise inside the car or having odors inside as well. Any info would help
camarosspower is offline   Reply With Quote
Old 08-04-2018, 02:13 PM   #2
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
No additional noise or smells. Car should have had an access from the factory. Can fit a cover over it when you're done of you want to be extra fancy
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 08-04-2018, 02:38 PM   #3
camarosspower
I would also need to cut one for the fuel level sending unit so it would be 2 holes on there.
Old 08-04-2018, 04:26 PM   #4
fif_gen_powa
Fuel level sending unit is attached to the pump assembly it's all together
8.3@164
Old 08-04-2018, 05:33 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I did it and dont regret it. I did put a cover on it. No smells or extra dirt.
Old 08-04-2018, 08:26 PM   #6
camarosspower
Wouldn't another hole have to be cut to pull it out?
Old 08-04-2018, 10:56 PM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
No, the entire assembly (bucket and level indicator) will come out of the same hole as one piece.
Old 08-04-2018, 11:03 PM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Old 08-04-2018, 11:46 PM   #9
707 SS
707 SS's Avatar
Drives: 2010 2SS
https://www.camaro5.com/forums/attac...1&d=1533444366
707 SS is offline   Reply With Quote
Old 08-05-2018, 12:17 AM   #10
camarosspower
I always thought the fuel pump was on one side and the sender on the other side?
Old 08-05-2018, 12:36 AM   #11
fif_gen_powa
Fuel level sender attached to the pump
8.3@164
Old 08-05-2018, 01:14 AM   #12
camarosspower
What's the other one on the other side? I also need to install the connector tube.
Old 08-05-2018, 01:18 AM   #13
camarosspower
I have the adm twin pump in it now. Going with the agp twin pump. So I need to have everything removed to be able to sell it
Old 08-05-2018, 01:53 AM   #14
mrimpala02
Drives: Black 2SS RS w/White Stripes
If you have the ADM twin pump you have two options as far as aftermarket pump options. I just did the same exact swap over to the AGP/FORE triple. ADM uses the CTS-V fuel transfer unit (driverside unit). The crossover tube diameter is 3/4" vs 1/2" on the camaro. So to have the correct crossover fitting on pump side you have to go with a CTS-V hat from Fore. Also the fuel level float mounts differently on CTS-V vs SS, wired differently and produced by a different OEM manufacturer. More complicated than just swapping back to your stock float. Using a CTS-V Fore module was the simplest route to negate these issues without dropping the tank. But like you said you are stuck with an ADM unit missing the other half of the CTS-V unit. Maybe it's worth buying these parts to complete the kit again to sell. Or maybe some CTS-V guys needs a factory replacement.
If you decide to go with a SS Fore hat you will have to drop the tank and switch everything back to stock first including the recalibration used for the fuel level sensor. These was a viable option for me because Lethal Racing did my ADM pump install and I guess tossed my stock parts.
Just good for thought. I chose to cut the hole and think it was a great idea. It will make maintenance in the future a breeze. I used the hatch that Blake-b linked in another thread with some knockoff dynomat on the underside of the lid and frame. It seals up pretty good and I barely even hear the pumps run.
I used air shears (harbor freight specials) to cut the hole which cut like butter. Just be warned the tank is really close to the floor near the drivetrain tunnel. Hit me up if you got questions!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
