02-13-2020, 07:14 PM | #1 |
Drives: SS Join Date: Apr 2019
Aux Fuel Pump: SMG/Hobbs Kit
Hey everyone,
Any users on here running the SMG aux pump kit? I know it uses a hobbs switch for activation. How has it been working out? Has it been reliable? Does the hobbs activation effect any tuning? Thinking of going that route. Thanks. |
02-13-2020, 08:00 PM | #2 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Why not run the DSX?
02-14-2020, 12:23 PM | #3 |
Scott S
Drives: 2011 Camaro 2SS Join Date: Sep 2018
I am running the SMG Aux kit with flex fuel and E85 no issues. It is a couple hundred cheaper than DSX kit also.
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
02-14-2020, 01:45 PM | #4 |
02-18-2020, 11:26 AM | #5 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
I would steer clear of any SMG branded part. I happen to know the owner and guy who works for him. There is a reason why they both do not run their own SMG aux pump kit.
02-18-2020, 11:30 AM | #6 | |
With a hobbs switch you will get a sudden hard surge in fuel pressure, which causes all kinds of tuning nightmares of which no one talks about or do not care that it happens. When the fuel pressure swings wildly you get rich and lean surges that follow. At the end of the day it is not the pump itself, it is the quality of the fittings hose and control system that sets them apart. Never skimp on fuel system, most engine failures can be linked to lack of fuel supply. Ted.
www.jannettyracing.com
02-18-2020, 02:28 PM | #7 | |
Drives: All things Turbocharged Join Date: Dec 2010
Wow, I didn't even notice that till you mentioned it. Sudden on/off with no fuel pressure regulator. Seems like typical trash sold today with no thought or standards behind it. But it's cheap so they'll sell tons. |
02-18-2020, 03:24 PM | #8 | |
Drives: 2011 Camaro SS Join Date: Jul 2017
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
02-18-2020, 03:31 PM | #9 | |
I do know they use a Map signal, and I believe a soft start system.
02-19-2020, 09:39 PM | #10 | |
02-19-2020, 09:57 PM | #11 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
If you have a return system the regulator would keep it from a large pressure spike. The dsx aux pump system is advertised as being run with the stock non return style system. It's commanded on by boost pressure and unsure if it's also linked to the fpcm, or the fpcm just lowers the demand for the in tank pump.
02-19-2020, 10:05 PM | #12 | |
I ended up talking to a handful of very competent tuners on this. Tuners that deal with this all the time, and have this platform down to the wire. Since the car has an FPCM, making changes along with other things will not cause any of these issues. You just have to know what you are doing. |
02-20-2020, 07:11 AM | #13 | |
02-20-2020, 07:28 AM | #14 | |
If tuning with HPtuners we can get in to the FPCM and make adjustments to improve the pressure spikes.
