02-21-2020, 12:39 PM | #1 |
Drives: 2014 Camaro 2SS/RS 1LE Join Date: Dec 2019
Would you guys be worried about how it idles?
Seems like it hiccups but I may just be ocd
2014 1le Arh longtubes No cats Corsa sport 3in system https://youtu.be/n6Jf5ZSQVxc |
02-21-2020, 02:08 PM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Sounds perfectly normal.
02-21-2020, 02:55 PM | #3 |
Drives: 2014 1SS/RS, LS3, NPP Join Date: Feb 2019
Mine does the same thing (still) and I used to wonder as well. But after reading on it, seems to be normal.
Your car sounds awesome btw! |
02-21-2020, 03:33 PM | #4 |
Haha im ocd then. Thank you guys!
02-21-2020, 03:40 PM | #5 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
way too smooth...you need a bigger cam.
NY5thgen.com
02-21-2020, 03:55 PM | #6 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
02-21-2020, 03:55 PM | #7 |
Tri-County Camaro SWFL
Sounds like my car with longtubes and stock tune
02-22-2020, 07:39 AM | #8 |
Sounds perfect to me! You can hear the stock cam working. You can hear that on all the 5th Gens LS3 cars with an aggressive after market exhaust. Now go get a bigger cam! lol. By the way, love that wicker on the rear spoiler, where did you get that from.
02-22-2020, 07:53 AM | #9 | |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
02-22-2020, 09:14 AM | #10 | |
You’re right, and ZL1addons.com and this one is the “stealth” wicker bill |
02-22-2020, 09:16 AM | #11 |
02-22-2020, 10:35 AM | #12 |
I.AM.
here's how it could sound...
https://youtu.be/0Gy2NAf7bm4
NY5thgen.com
02-22-2020, 01:32 PM | #13 |
My LS3 sounds like this, almost sounds like a random miss at idle. When I had my L99 it idled smooth as butter. My LS3 definitely idles a little bit rougher, which is fine by me. It's just the slightly higher lift stock cam in the LS3.
02-22-2020, 05:29 PM | #14 |
^^^^ Totally correct sir ...
