02-26-2020, 06:48 PM | #1 |
Drives: 2013 2ss hotwheels Join Date: Aug 2014
BTR 3 ADVICE
Got the kit ,high volume oil pump,c5 r timing chain,new tensioner, what else should I have done while there in there. Speed inc in Schaumburg I'll installing. What should I be telling them I want done.3 weeks away.
02-26-2020, 07:24 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
New cam retainer plate, often over looked and new one should be used every time it is removed , new bolts for it as well
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
02-26-2020, 08:51 PM | #3 |
Thanks, all the bolts that come out need to be replaced?
02-26-2020, 09:13 PM | #4 |
Glad you mentioned that man. Ordered my new cam kit today but I forgot that. Do you know if the LS3 uses the newer style with the countersunk bolts or does it use the old style?
02-26-2020, 10:38 PM | #5 |
Also which breaking oil is best . I see alot of br30
02-27-2020, 02:42 AM | #6 |
Ive never replaced the plate or used break in oil.
02-27-2020, 05:21 AM | #7 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
lol, i was just thinking that. just clean the bolts and use a drop of loctite.
OP, you said "new tensioner". Does that mean a new ls3 style, or a new ls2 or "dogbone" style? Somehow my ls3 tensioner is still kicking, but i picked up a dogbone for the new build.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-27-2020, 06:15 AM | #8 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I wouldn’t have Speed Inc do it.... That’s just my opinion...
Springs Pushrods Trunion upgrade (if you want) LS7 lifters (if you want) Supercharger....... :/ |
02-27-2020, 06:28 AM | #9 |
Drives: 15 Camaro SS Join Date: Oct 2018
If its even remotely a question in your mind, change it. Im in the middle of the gpi max kit install and ive changed everything to something better that ive taken off lol. Figured do it once
02-27-2020, 08:08 AM | #10 |
Who would you have do it and why?
02-27-2020, 09:22 AM | #11 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I reused the plate, cleaned the bolts and used blue Loctite. They are torx recessed bolts. I used calcium-sulfonate grease on the cam lobes for assembly. Ran it 25 minutes varying rpm 1800-2500rpm. changed oil and added ZDDP to the oil. A lot of people don't seem to do a break in on roller cams. I also see some that have wiped out cam lobes and lifters at 5k miles. So I will always do a break in procedure can't hurt, can only help.
02-27-2020, 09:48 AM | #12 | |
Yes its the newer style one with countersunk bolts , i am aware that you could resuse it. But ive read horror storys of the gasket it has built in not sealing good any more and guys being way down on oil presser from it. I dont like to take that chance and got new one. 20 bucks well spent in my opinion
02-27-2020, 09:50 AM | #13 | |
That's how i think too
02-27-2020, 10:09 AM | #14 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Save your money on a cam retainer plate and new bolts. No need. Retainer plate failures are very VERY rare. Just a dab of some loctite and you're good to go. Go with the dogbone tensioner, less working parts to fail compared to the stock ls3 unit.
Don't really need too much for a cam swap. Just make sure you have some new, good plugs for the tuner. Most tuners like to tune on silver or copper plugs. They don't last as long as iridium or platinum but they perform a lot better.
GJDM |
