05-29-2018, 03:23 PM | #1 |
Drives: 2013 1SS Join Date: Oct 2017
Stalling/Low Oil Pressure light
So my car has been stalling randomly at idle and when i would rev the engine a little for the past week or so. The other day on my way home from work it stalled and the Low Oil Pressure light came on. I pulled right over and had it towed to my shop. He tells me nothing is leaking and oil pressure is 30 at idle and 60 when you rev it. The car still has the problem with stalling but the light is not coming on anymore and my mechanic doesnt know what the problem is. Any ideas?
05-29-2018, 03:51 PM | #2 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
A trip to your local Chevy dealer will figure it out and solve your problem , and if it is still under the 100000 mile gm warrantee it may be free .No matter what it needs to be checked out B4 something bad happens.
OLD GUY FLYING FAST AND LOW
05-29-2018, 03:58 PM | #3 |
lol i highly doubt that will happen. The car is cammed among other mods.
05-29-2018, 04:07 PM | #4 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
If your mechanic is using a mechanical gauge to test pressure, and it's testing fine, then I would imagine your car is using an electrical sensor and that is going bad.
If it's not the electrical sensor, hopefully you don't have cam bearings already on the way out.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-29-2018, 04:09 PM | #5 |
No where in your post did you reveal that it was a heavily modded car . , in that case the cost would be on you . But the dealer would only charge you 1 hour to diagnose the problem and find our what the problem is . Did you do the mods ? did a shop do the mods ? If a shop did it bring it there and let them have a better look at it . If that fails bring it to a shop in Florida that knows what they are doing . Tampa Tuning is a good place to have a look at it .
05-29-2018, 04:50 PM | #6 | |
05-29-2018, 05:49 PM | #7 |
Plug in a scanner that has live time ability and drive it and you may figure out where your problem is , or head on over to Tampa Tuning and let a pro diagnose it .You spent the money to mod it ,so spend some money to fix the problem . Or if you believe it is an oil pressure sensor take a shot and replace it ,under $40.00 and easy to do .
05-29-2018, 08:24 PM | #8 | |
lol all of that has already been done besides a sensor which I dont think is the problem because there is no CEL or codes. I asked for ideas of what the problem could be not ideas of where to bring it. |
05-29-2018, 09:22 PM | #9 |
Drives: cars Join Date: May 2011
You need to fix the stalling. An engine dying from no rpm means no pressure, idiot lights come on. I'd swap plugs/wires and inspect connections on coils and injectors, engine grounds and battery wires and battery condition.
Dealers are too dumb to change the oil correctly let alone diagnose something with no code. |
05-30-2018, 08:26 AM | #10 |
Not necessarily, but it would throw the low oil pressure light even if you aren't low on pressure. I would start with a simple sensor and see if it helps, if not take it in for a proper diagnosis.
And just because you aren't getting a CEL doesn't mean the car isn't reporting fault codes.
05-30-2018, 11:34 AM | #11 |
You can lead a horse to water , but you can't make him drink . If you or your so called shop/installer can't figure it out by now seek out a real pro who can. And if I were you I would also get an oil analysis done asap. If it were mine I would cut open the oil filter and see what's in there B4 sending the oil out for analysis . What ever you do I would stop driving it until the problem is resolved.
06-02-2018, 04:25 AM | #12 |
I would look at MAF sensor, maybe swap it out for another to eliminate or look for air leak
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
