Old 06-09-2018, 07:14 PM   #1
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
Cruse control
I installed wider smaller tires on my Camaro, (what a diff that made) but now my Cruse Control is not working, is it because the computer see's a diff diam tire, so it doesn't turn it on??
gutterball is offline   Reply With Quote
Old 06-09-2018, 07:21 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Did you only change the front or rear tires? The tires have to be within 1" of each other height wise
DSX_Camaro is offline   Reply With Quote
Old 06-09-2018, 07:41 PM   #3
gutterball
gutterball's Avatar
Both-If you change just one and not the other, The computer cuts down your Power because of traction control
Old 06-09-2018, 07:45 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Right. That would be why your cruise control wouldn't work too, if you did one set and not the other, which is why I asked. So then no, that isn't why. Your speedometer would only be off.
Old 06-09-2018, 07:48 PM   #5
DSX_Camaro
DSX_Camaro's Avatar
Since you have a manual like I do, could be your clutch position sensor, or a part privy to that. The body control module has to make sure the clutch pedal isn't pressed, and other guys with manual V6s have had the same issue.
Old 06-09-2018, 07:53 PM   #6
gutterball
gutterball's Avatar
Don't know, cruise control worked before changing tires, It could be that the cruise control is calibrated for your original diam tire, now it sees a diff diam so it doesn't turn it on
Old 06-12-2018, 06:17 PM   #7
gutterball
gutterball's Avatar
Well it's not the diff diam tires, yesterday Cruise control worked great, today no
Old 06-12-2018, 06:35 PM   #8
DSX_Camaro
DSX_Camaro's Avatar
Yeah, like I said, it's probably your clutch or brake position sensor.
