#Camaro6
Old 06-04-2018, 09:15 AM   #1
TheWiseWolf
Drives: Camaro
Switching Gas on V8
While switching different octane (reg,plus,premium) fuel do any type of damage to the V8? I know the V6 can take reg fuel but can the V8 as well? Maybe not all the time but on days you know you wont be needing that higher level of fuel.
TheWiseWolf is offline   Reply With Quote
Old 06-04-2018, 09:18 AM   #2
98_Camaro
98_Camaro's Avatar
Drives: 2016 2SS Coupe
The car will retard the timing and drop the horsepower into the low 300s. Not worth it to save at most $5 a fill-up.
Gone but not forgotten:
1998 Bright Purple Metallic Camaro
2012 Carbon Flash Metallic 2SS Convertible
2016 Summit White 2SS Coupe M6, NPP, & MRC
Now Driving:
2016 Torch Red Corvette 2LT, NPP, MRC
98_Camaro is offline   Reply With Quote
Old 06-04-2018, 09:33 AM   #3
SSport16
SSport16's Avatar
Drives: 2016 Garnet Red Camaro 2SS
Premium only for the LT1 V8. You can use lower octane, but it will damage the engine after using long term. Like mentioned above not worth the extra few $.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered)
3800 Status - 10/13/15 (Built)
6000 Status - 12/22/15 (Delivered)
SSport16 is offline   Reply With Quote
Old 06-04-2018, 11:17 AM   #4
2SSVERT
2SSVERT's Avatar
Drives: 17 garnet red 2ss vert
Originally Posted by SSport16 View Post
Premium only for the LT1 V8. You can uelse lower octane, but it will damage the engine after using long term. Like mentioned above not worth the extra few $.
It will not cause damage using lower octane fuel, you will get significantly lower fuel mileage and performance. The computer will pull timing to protect itself. That being, I wouldn't be doing a lot of spirited driving on regular gas.
2SSVERT is offline   Reply With Quote
Old 06-04-2018, 11:33 AM   #5
a143gsxr
a143gsxr's Avatar
Drives: 2016 1SS
Yes exactly as stated here. 87 and 89 will not hurt but if you plan on visiting the track or beating on the car a little use 93 during those times.
a143gsxr is offline   Reply With Quote
Old 06-04-2018, 12:03 PM   #6
brAnd7onX
brAnd7onX's Avatar
Drives: 2012 1SS IOM
Sigh... why do people buy V8's if they can't afford the gas...
2012 Camaro SS IOM "TigreSS"
Borla "S" Catback
C.A.I. Intake
VMax Ported TB
JRE Tune
brAnd7onX is offline   Reply With Quote
Old 06-04-2018, 12:11 PM   #7
JT58
Drives: Former 2016 Camaro 1LT
Sometimes things change in life- jobs, our commutes, etc. Rather than put regular gas in my Gen 5 SS and invest a lot of money for body work for dents and repairs, I traded it for a new Gen 6. I got the V6- main reason living on a tight budget and gas. I was able to buy a new car, perhaps some others cannot afford to do so.
It would be nice of the SS would take E85- if you have it available where you live. It's 50 cents cheaper than regular per gallon where I live.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 06-04-2018, 12:15 PM   #8
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
its always a chance of this and chance of that.
imo for something I spent 50k on, I wouldn't chance a thing especially for a few dollars extra.
i put reg in my Silverado ss once and i def noticed the difference and just off that experience im done playing with fire probably for the rest of my life haha.
Kise is offline   Reply With Quote
Old 06-04-2018, 01:03 PM   #9
ctrlz
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP
Beats me. Here in NJ (last state without self-serve gas), the attendant where I fill up tells me that most sports car owners ask for regular. He always compliments me for using premium! And this is a busy station on the way into a shore town known for its college-aged crowd (sea isle city). I see a lot of V8 Mustangs and Corvettes there.
The practice seems to be more common than I thought!
ctrlz is offline   Reply With Quote
Old 06-04-2018, 01:07 PM   #10
DeliveryMan
Drives: 2016 Camaro 2SS
C'mon man. put the high octane in the V8. says right on the Fuel door
DeliveryMan is offline   Reply With Quote
Old 06-04-2018, 01:15 PM   #11
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
It'll compound too. Lower octane means less power and less timing, meaning in low rpm high load scenarios (like cruising on the highway) it'll get worse gas mileage, which in turn means you'll be filling up more.
It's your car and you can do what you want with it. Just cringe worthy to me, like seeing a 6th gen SS without NPP. (I didn't even know it was possible until I saw one a few weeks ago with dual tips instead of quad... I've only seen NPP SS's for the last 2 or so years)
DSX_Camaro is offline   Reply With Quote
Old 06-04-2018, 04:17 PM   #12
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
I agree with all those above, why take the risk. If it's a daily driver and things around the $$$ have changed for the worse in the meantime, I'd lean less on the pedal and shoot for better mileage to save money.
Call me nuts, but I'm even unhappy about the small amount of 87 that makes it in from the pipe before the 93 starts flowing... I haven't yet found a good station near me that has a separate head for premium.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is online now   Reply With Quote
Old 06-05-2018, 06:42 AM   #13
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
'Bout time someone mentioned that first gallon of 87 !!! Paying premium price for crap-gas!
mdhopt36 is offline   Reply With Quote
Old 06-05-2018, 11:49 AM   #14
indyz
Drives: 2SS, CT-R, LC500
On the highway, and long trips, it will behave fine, since you are usually cruising. Around town, 93 (or 91) will work best, since one is usually "hitting" it .
indyz is offline   Reply With Quote
