Old 04-22-2019, 11:20 AM   #1
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Tires are spinning on the wheels when I launch
I have 17X9.5 Race Star wheels with 275/40/17 M/T ET Street R rears. The tires keep spinning on the wheels when I launch. They move about 2 inches each hit:
I talked to a guy at the track who claimed to be the local Race Star dealer. He said that I need to dismount the wheels and remove the powder coating from the bead area, rough it up and i should be good to go.
Has anyone solved this issue with their Race Stars? Did you do what dude told me to do or something different?
CAI Cold Air Intake; Comp Cams LSR Series; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; AEM Wideband; N2MB WOT Box;
Tuned by Throttle Works 467whp 419 wtq
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 04-23-2019, 10:39 PM   #2
zlathim
zlathim's Avatar
Here's how I decided to fix the slipping tire issue.
I removed the powder coat from the bead seat areas with a wire wheel mounted on a drill. Then I lightly scuffed up the same area with a 60 grit flapper wheel on a grinder. After that, I used an automatic center punch to make a row of stipples about every inch along the outside edge of the bead seat area. I'm going to have the tire guys use Windex to mount the tires tomorrow. I'll report back after the weekend race with the results.
Old 04-23-2019, 10:57 PM   #3
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Get this man some beadlocks! Hope it goes well Z. I have the same wheels as you, just polished. I couldn't help but notice the skinnies in the picture. What wheel and tire combo are you running up front?
11.079 @ 122.99mph
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 04-23-2019, 11:37 PM   #4
zlathim
zlathim's Avatar
17X4.5 Race Stars wrapped with 26x4.0/17 M/T ET Fronts
Old 04-23-2019, 11:53 PM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Have them use bead sealer...doesn't stop it(nothin does) but it slows it down a bunch...I'm gonna save up and get the Carlyle 15 kit...best way to go especially if you want to turn it up later.
good luck..
Peace
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 136K! - All work by me...
Old 04-24-2019, 09:30 AM   #6
zlathim
zlathim's Avatar
Thanks, Frank!!
Old 04-24-2019, 05:20 PM   #7
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
I haven稚 got mine to the track yet to see if I will have the same issues. I told the tire installer to please do whatever is needed to the rims to be sure they don稚 spin in the tire and told him I値l be dropping the tire rear pressure down to 17 psi. He used bead lock sealant on them. We値l see how it goes but I知 gonna personally guess I値l be doing the same thing you did by shaving the inner part of the rim coating off. Yours should be good now cleaned like you did. I would definitely use bead sealer on those though. I heard to this is the best solution to fixing the slippage.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 04-24-2019, 11:42 PM   #8
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Z/28 wheels come with sand in the paint on the beads, if memory serves me correctly.
chef-beavis is offline   Reply With Quote
Old 05-19-2019, 03:44 AM   #9
zlathim
zlathim's Avatar
Attachment 984509
All good now. I have a little more than an inch of slip after almost 30 hits. I can live with that.
Old 05-19-2019, 10:33 AM   #10
Vegas Bound
Drives: 2013 Sparkly Red One
I get free balancing from Discount Tire. I take the rears there every few months.
Lots of bolt on stuff
1.36 60'
6.29 1/8 mile
TBD 1/4 mile
Vegas Bound is offline   Reply With Quote
Old 05-19-2019, 01:08 PM   #11
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Did you notice much difference in your 60'? I think I may have the same issue.
StingrayblueSS is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
