04-20-2018, 04:54 AM | #1 |
8" Wheels Square Setup?
Has anyone done this to their Gen5? I plan to go 20x8 wheels all around and am just wondering how the narrower wheels/tires look on the rear.
Wondering if there needs to be spacers on rear to push them out even with fender wells. Pictures appreciated. Thanks.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
04-20-2018, 11:22 AM | #2 |
Drives: camaro Join Date: Nov 2011
20X8?? IS THERE A REASON WHY??
I mean to be honest you will be taking away from the car by doing so. your minimum width should be what your factory wheels are which I believe is 20x8.5, especially with so many wheel options around I just dont see why you would settle on a 20x8 for a camaro which clearly would be best with more traction. |
04-20-2018, 01:41 PM | #3 |
Drives: 2011 Camaro 2SS Join Date: May 2016
I'm with Carlos here...why would you ever go with a 20x8 unless its for a winter tire or something? it'll look horrid anyway
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
04-20-2018, 02:13 PM | #4 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Go 20x9 all around if you want a square setup, I imagine you are doing 20x8 so that your tires fit in the front and keep it square, but you can do 275/40 on all 4 corners with a 20x9 rim.
It's what I run in the summer.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
04-20-2018, 08:34 PM | #5 | |
04-20-2018, 08:52 PM | #6 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
I have two sets of OEM 21" wheels along with my original 20" polished aluminum. The two sets of 21" are RPO codes VZP and VZN. The VZP have 8.5" wheels on the front and 9.5" on the rear. The VZN is a square setup with all four wheels being 8.5". The square setup is factory wrapped with Pirelli P Zero 345/40ZR21".
Looking at my car you don't see any difference what so ever. GM catered to the V6 models with the square setup and the V8 with the VZP package, however both sets will work and look great on either.
04-21-2018, 12:52 AM | #7 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
You are correct. They are not 8.5 up front. But, as others have mentioned I don’t understand why you would want to ruin the handling, braking and looks. At least go with the factory 20x9’s all around on 275’s. This is a proven setup that looks good and reduces some understeer.
04-21-2018, 03:58 PM | #8 | |
Assuming I go through with this, as soon as someone says "Oooo, where'd you get the skinny little tires"... I'll let you know and you can say "I told you so". Thanks for the input.
04-21-2018, 05:32 PM | #9 |
Ok, ruin may have been used to embellish what the results may be, but, there will be a degradation in handling, braking and appearance. You will not have to spend a grand to upgrade. A couple 20x9 SS wheels would be ~$200 and a new set of smooth running 275-40-20’s would be about $300. IMO, this is the correct, inexpensive way to achieve a square setup. Good luck.
04-22-2018, 05:45 AM | #10 |
You can just look at a v6 model to see how it will look in the rear with 245s. They are on an 18, but width wise it will be the same.
IMO my winter setup sits inside the wheel well a little too much, and doesn't look nearly as good.
04-22-2018, 08:22 AM | #11 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Quick question.......If you have your mind already set on this option, and seem to have all the answers, then why post? Just do it.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-22-2018, 08:50 AM | #12 | |
04-22-2018, 09:00 AM | #13 | |
But you are right - I have my mind made up, but was mostly concerned about spacers. I don't want the 8" wheel/tire combination to look too "narrow" in the fat rear fender wells.
04-22-2018, 09:36 AM | #14 |
This is how a 245 looks in the rear
Personally I don't like it very much, but it works well in the winter time. This is my 20x9 square set up with 275/40 all around: This looks flush in the front and the rear and I very much prefer this look.
Thread Tools | |
