Old 07-29-2013, 10:12 PM   #1
cipriank
cipriank's Avatar
Drives: 2010 camaro 2ss
underdrive pulley feedback
can anyone tell me how different the car drove after the under drive pulley install? noticeable improvement ?
2010 2ss L99
Mods: ADM race intake, ADM scoop w/ washer bottle, SLP long tube headers, SLP 25% UDP, SLP Loud Mouth 2 exhaust, Vmax TB, BER intake manifold,3.45 gears, MSD wires, SLP 160 t-stat, SLP Springs,
EFI live tune by Redline Motorsports
cipriank is offline   Reply With Quote
Old 07-29-2013, 10:27 PM   #2
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
I consider a UDP one of those since I'm in here mods to do when you do a cam. I don't feel the return is worth the trouble unless you already have a reason to have the factory pully off. Car is not going to drive differently, but the butt Dyno might be able to feel it a little. Don't even waste your money on a 10% UDP, get a 25% one.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 07-30-2013, 05:50 AM   #3
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
I agree with Mickey. Only bother with it if you are doing something else that requires the labor to pull the old one off. My car drives fine with it. Zero problems.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 07-30-2013, 10:52 AM   #4
Jason 98 TA
Drives: Camaro
We typically see 8 rwhp from a pulley install.
Hang tight, we are finishing up a run of TSP's new underdrive pullies & I promise the price will be nice!
Jason 98 TA is offline   Reply With Quote
Old 07-30-2013, 12:22 PM   #5
Kelly@PCMofNC
Drives: 2010 RS/SS
Agreed!
Kelly@PCMofNC is offline   Reply With Quote
Old 07-30-2013, 12:46 PM   #6
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Do you got a projected time when it'll be out? I'm about to order my long block from you guys and would like an under drive pulley very much to go with it.
Nightmare2012 is offline   Reply With Quote
Old 07-30-2013, 12:57 PM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
It will rev quicker, and yes pickup 7-8 hp/tq
Rhino79 is offline   Reply With Quote
Old 07-30-2013, 01:02 PM   #8
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
but if you stall in parking lots when taking tight turns at low rpm (like I do because of having a big cam)... an underdrive pulley will make it worse (reduced power steering pump power).
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 07-30-2013, 01:38 PM   #9
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
On my car, I noticed that if I sit in the parking lot at work like I sometimes do at lunch, it will go into Battery Saver mode on the DIC and the AC will reduce power. But I'm a bit different, due to the fact that most of my driving is under 35 mph commute to and from work so rpms dont turn that high to charge the battery. Not to mention I have a BIG A$$ stereo system with 2 BIG AMPS.
Camarojt is offline   Reply With Quote
Old 07-30-2013, 02:17 PM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Your stereo is most likely the culprit, I commute today I never went above 30 mph. I have 9,000 miles on my 25% underdriven pulley, trouble lights or battery issues. I did 3 other mods at the same time so can't comment on the performance.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-30-2013, 02:51 PM   #11
LeanPocket
Drives: 2010 2SS
its about 8-12 hp and about .1 off the 1320' for 300$.. if u can justify that, then I say its well worth it.
LeanPocket is offline   Reply With Quote
Old 07-30-2013, 04:04 PM   #12
TXISKING
TXISKING's Avatar
Drives: '13 ZL1 725 rwhp / 700 ft lb tq
Does the 8-12 hp numbers increase to a bigger number, if you have done heads and cammed already? Or is it a static number?
'13 Black Manual trans , Heads, Cam, Injectors, Ported Snout, Vmax throttle body, RotoFab, Headers, No Cats, 9.55 lower pulley, D3PE heat exchanger, - 725 rwhp/700 tq
TXISKING is offline   Reply With Quote
Old 07-30-2013, 05:25 PM   #13
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
A UD pulley doesn't cause a gain in HP as much as it reduces parasitic loss from spinning the accessories 25% slower. So my guess is the 7-8 HP is a static number.
For those with cams and stalling and/or charging issues - might the idle be too low more so than impact from a UD pulley?
OP - I did my UD pulley with the cam swap. As others have said I can't recommend it as a stand alone mod.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 07-30-2013, 05:35 PM   #14
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
I would not do a pulley unless I was doing a cam. The install is a pain on it's own for the little bit of gain you get. Thanks!
MarylandSpeed is offline   Reply With Quote
