Old 01-27-2014, 06:04 PM   #1
Seca Turbo
Drives: 2010 Synergy Green Edition
BG Synchro Shift Manual Transmission Fluid
Has anybody tried this?
http://www.lancershop.com/customer/p...p?productid=50
Seca Turbo is offline   Reply With Quote
Old 02-02-2014, 01:38 PM   #2
Seca Turbo
Anybody?
Old 02-02-2014, 02:52 PM   #3
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I didn't try that, but when I did my research, a lot of people claimed the same results using RP Syncromax.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 02-02-2014, 02:55 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Why use that when we all know that the Redline D4 works so well?
shibbs is offline   Reply With Quote
manual transmission fluid
