Old 02-04-2014, 12:47 PM   #1
Twin2010
Drives: 2010 twin turbo ss
TWIN TURBO LS3 2010 FUEL SMELL INSIDE CAR?
I have a 2010 ss twin turbo with 3 inch magna flow exhaust. It has a squash fuel system with the teflon line to eliminate fuel odor. When i am cruising the car it seems i always get a fuel odor inside, even when i have tha air on recirc. I was curious if anyone else ran into this same issue? Im not sure if it is because i dont have cats or what. If its from that i am almost thinking of putting high flow cats on it with electric cutoutsto activate under boost. I cant stand any kind of fuel smell inside while driving. Thanks for any input
Twin2010 is offline   Reply With Quote
Old 02-04-2014, 01:07 PM   #2
kpwalls06
Cory
kpwalls06's Avatar
Drives: 2010 Camaro 2SS/RS M6;
When you say fuel odor do you mean it smells like gas when you fill your car, or does it smell like the car is running rich? Each smell would likely mean a separate issue with the fuel, I would think.
kpwalls06 is offline   Reply With Quote
Old 02-04-2014, 01:15 PM   #3
Twin2010
Ya i was just thinking about that. I think its almost a raw fuel smell. I cant see anywhere the fuel system is leaking. Im not sure if theres a way to smoke test the system to see if theres a leak somewhere
Old 02-04-2014, 01:18 PM   #4
CyberPredator
50 Shades of Prey
Drives: TT/SS
Raw fuel, I would say check all connections. Rub your finger on each connection and feel for moisture or dirt build up (smell too). If it's burnt fuel, I would say check for exhaust leaks and route crank case ventilation to somewhere further from the cabin (if open).
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 02-04-2014, 01:20 PM   #5
kpwalls06
Cory
kpwalls06's Avatar
If the fuel is leaking, there's a decent chance it's hitting somewhere on the undercarriage of the car and evaporating due to the heat. The evaporation releases the vapors, causing that smell. I couldn't really offer advice on smoke testing, or other ways to leak test your system, but it would be a good place to start if the smell is more like raw fuel.
Old 02-04-2014, 02:10 PM   #6
Camper
Banned
Drives: 10' 2SS LS3 M6
id start carrying a fire extinguisher TBH
Camper is offline   Reply With Quote
Old 02-04-2014, 02:43 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Was the pump installed by dropping the tank or by cutting a whole under the back seat?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 02-04-2014, 02:48 PM   #8
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
casper sc/1ss/rs is offline   Reply With Quote
Old 02-04-2014, 03:01 PM   #9
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Check for leaks smell around the fuel pressure regulator as well.
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons)
2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 02-04-2014, 03:41 PM   #10
Twin2010
I pulled the tank out of the car to install everything
Old 02-04-2014, 03:51 PM   #11
camarostar2010
Drives: 2011 SS
assuming all is tight..then the smell is from no cats and running slightly rich...which is good overall. U can ask your tuner to lean out a lil..and the rest is basically "the way it is". Also u might get a lil vapor smell after shutting off the engine in really hot environments. My experience. I also checked for leaks, but found none. Keep us posted.
camarostar2010 is offline   Reply With Quote
Old 02-04-2014, 04:15 PM   #12
Twin2010
Its weird i get the smell just cruisin gdown the highway and the air fuel is 14.5-15.0 cruising down the highway
Old 02-04-2014, 04:35 PM   #13
DKT
DKT's Avatar
Drives: 2013 Camaro 1LE
I had a magnafuel fuel pressure gauge blow apart and starting dumping fuel out of my rail. I only noticed a slight odor nothing major, it wasn't until i realized i went through a 1/8 tank driving across town did i know something was wrong.
DKT is offline   Reply With Quote
Old 02-04-2014, 09:33 PM   #14
Chris82xx
Chris82xx's Avatar
You upgraded to the Squash which means that you probably upgraded your injectors too. Are they all sitting correctly? If not, you could be blowing fuel out from one.
811RWHP/719RWTQ
