#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction Discussions
Old 07-23-2019, 11:20 AM   #1
thebanks06
thebanks06's Avatar
Drives: 2016 Chevy Camaro 2SS
Anyone tried these new Heat Exchangers?
I saw Speed Engineering release a set under the radio for zl1 and cts-v, I wonder how they fair especially for the price.
https://www.speed-engineering.com/sh...lac-cts-v.html
thebanks06 is offline   Reply With Quote
Old 07-23-2019, 11:39 AM   #2
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
less than half the price of the Weapon X brand
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 07-23-2019, 02:15 PM   #3
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
They look really well built
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 07-23-2019, 02:20 PM   #4
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Great price... Would love to try them... but reading about their headers I dont know If i'd wanna be the first one.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 07-23-2019, 02:28 PM   #5
thebanks06
thebanks06's Avatar
Exactly!
Old 07-23-2019, 02:29 PM   #6
thebanks06
thebanks06's Avatar
They do, that's why i was asking. If they are built like they look, they would be a winner
Old 07-23-2019, 02:30 PM   #7
thebanks06
thebanks06's Avatar
Yea it seems like they are a hit or miss, especially the holes being bolted up. Really thought about pulling the trigger though..Hope they chime in.
Old 07-23-2019, 07:50 PM   #8
newchevyman
Drives: 2017 Camero ZL1
Interested in these also. OP be the guinea pig for the rest of us!
2017 ZL1 A10
Dyno/Quarter Mile/Dragy
9.71@141.2 MPH so far.
2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold.
newchevyman is offline   Reply With Quote
Old 07-23-2019, 08:07 PM   #9
thebanks06
thebanks06's Avatar
I just might, if i do, I will definitely do a write up
Old 07-24-2019, 07:49 AM   #10
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
The thing about this is... if headers leak that's fine you can drive to an exhaust shop and fix it...
If this leaks, you're stranded. Obviously, before installing I would do the fill with water test but after install with heat cycles and long term pressures how will the welds hold up... That's what I'm afraid of.
Old 07-24-2019, 08:16 AM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
I would worry about the larger one being a direct fit easy to make a bracket the smaller one I think room would be tight!
I was even thinking about making a LS caddy or zl1 work from a 5th gen
I'd like to know thr dimensions...
I know the prospeed is 22 inches wide, 15 inches tall, 2.16 inches thick for 799.00
It gets complicated and there is theory behind how thick to make it.. with how much airflow it gets.. normally you would think the ticker the better.. For volume yes but maybe not for dissipating the heat.. I though I read the 1 3/4 was ideal since the velocity was faster there the fins.. now of course if you can get the air going through a thicker unit as the same rate that would be the best..
I been looking around to I think the side ones are a waste at 1100 bucks but now this maybe makes it worth it..
this is the eforce size for 350.00 Supercharger Heat Exchanger; Single Pass; Single Row; 31000 BTU/HR; 22 in. W x 16.5 in. H x 1.5 in. blk I can get for 350.00
I have even thought about running 2x 22 x 8 x 2 stacked.. dual passes all over ebay for 150 each
Anyhow that's a great deal..
BTW I called AFCO told them i would give them my OEM one and car for a replacement one they said they were just fixing to start the project..
The guy was thinking 5 to 600 mark for the AFCO there usually proud of there stuff to.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 07-24-2019, 08:49 AM   #12
thebanks06
thebanks06's Avatar
You make a damn good point
Old 07-24-2019, 08:50 AM   #13
thebanks06
thebanks06's Avatar
Yea I heard AFCO was pretty good, that would be an ideal price.
Old 07-24-2019, 11:42 AM   #14
JANNETTYRACING
JANNETTYRACING's Avatar
Here is something to thinks about.
The whole aftermarket industry seem to be chasing the wrong end of the donkey because it is easy and Oh we can sell that.
The Intercooler/s inside the supercharger is where the weak point is evident by the supercharger industry focus and where all the gains are made.
The Factory heat exchangers (the one out front) in most instances are more than adequate and do a fine job of dumping whatever heat the inadequate intercooler bricks can collect.
Not discrediting anything about aftermarket heat exchangers but Like EDFHOBBIES said there is a balance between air flow and cooling.
Bigger thicker heat exchangers restrict air flow to the AC condenser, Radiator, engine transmission Power Steering, and differential cooling.
The way I see things is the car comes with an Engineered Cooling Pack that balances all the air flow to each part of that cooling pack.
So you are robbing the many to feed the one.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
