05-23-2018, 04:23 PM | #1 |
Drives: 2015 1LE Join Date: Oct 2015
Valve Train Noise
After my cam install I am noticing increased noise from the valvtrain I think. I can hear it slightly when I am just cruising down the road and some at idle. Is this normal? Its driving me nuts, Its not real bad but it is still there. I did all pushrod measurements so the preload is correct, its about .075 or one turn. Is there anything that works to quiet it like rocker bushings?
05-23-2018, 04:30 PM | #2 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
I can hear a slight valve-ish noise when cruising certain RPMs, but it wasn't related to my cam swap. It was after I installed headers. At first thought it was a leak, then I realized I am literally just hearing the valves opening and closing through the exhaust tubing. Maybe that's what some of the noise is at least?
Does the noise seem to be coming from the valve cover area? Is it more prominent from under the car?
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
05-23-2018, 04:32 PM | #3 | |
05-23-2018, 07:48 PM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
bronze rocker bushings quieted my valve train down quite a bit....
peace
05-23-2018, 07:59 PM | #5 |
The LS sewing machine sound. your ok.
05-23-2018, 09:02 PM | #6 |
Drives: 2010 Camaro 2SS Join Date: Aug 2016
Thought I had bad valve train noise after doing heads cam lifters and trunnions even though the noise came from under the car. Turns out we didn't put my headers back together well and they were vibrating. Readjusted the coupler holding the collector to the x pipe and mounted the pipes closer together and now it sounds stock
05-23-2018, 11:16 PM | #7 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
I noticed today while I was waiting in line that my LS-3 has a slight valve tap at idle. Not too loud to worry, I have had many many smallblocks in my younger years that tapped.
I'll keep monitoring it though.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
05-24-2018, 07:59 AM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-24-2018, 11:41 AM | #9 |
05-24-2018, 01:14 PM | #10 |
You got a full turn preload so you have the right pushrod lengh. Thats about it dude. Some inluding myself run 7-7.5qts of oil instead of the usual 8. It seems to help.
05-24-2018, 01:39 PM | #11 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
i'd give it a shot next oil change if it really bothers you
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-24-2018, 02:25 PM | #12 |
I'm good with it, its just a little noisier than stock (it made noise then also).
05-25-2018, 12:34 AM | #13 |
Drives: 2013 Camaro SS Join Date: Feb 2017
That's the opposite of what I would think. I had thought about going a half qt. Over. Learn sitting every day here.
05-25-2018, 01:01 AM | #14 |
Granted Im not 100% sold on why but....
theory behind it is the oil level with 8qts puts it close enough to the crank that it airates the oil and it accumilates in the lifters and causes them to tick.
Thread Tools | |
