Old 06-03-2020, 04:21 PM   #1
TommyC
Drives: Chevrolet Camaro SS
Just installed 4.11 gears
So i had to post my impressions of the 4.11 motive gears. Quick overview of my car. 2015 2ss dynatech 1 7/8 LT, cai inductions with scoop, tuned 435hp/447tq. I decided to not go with trutrac because honestly im going to probably end up swapping in a 9 inch and I didn’t wanna waste more money on this housing. But anyways, the gears are QUIET AND DRIVES BETTER. The car no longer bucks at low speeds, i can use 5th and 6th far more often. Whats crazy is with the stock 20 inch rims, the shift points are 1st 43mph 2nd 62mph 3rd 90mph 4th 128mph. That is exactly the shift points in my old 4th gen z28 with 16 inch rims and 3.46 gears. I couldn’t be happier. This car pulls better in every gear. 5th gear is literally what 4th use to be. Which is crazy if you think about it. The car’s top speed was probably in 4th gear with the old differential. The car was a 4 speed with 2 overdrive gears. I highly recommend it. I can’t believe how much easier the car is to drive now around town and even cruising on the highway is better because you can just keep it in 6th and pass cars.
TommyC is offline   Reply With Quote
Old 06-03-2020, 06:39 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Awesome
I’m always on the boat on changing gears. I’m NA now but want to procharge it in the future and those high ratios might be too much then.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 06-03-2020, 09:36 PM   #3
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Originally Posted by Bigdumogre View Post
Awesome
3.91 then
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 06-03-2020, 09:48 PM   #4
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Welcome to the club. 4.10s should be one of the first mods anybody with an M6 car does. Essentially no downsides, and a lot to really enjoy!
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 06-03-2020, 09:54 PM   #5
Bigdumogre
Bigdumogre's Avatar
Originally Posted by pnwdan View Post
3.91 then
That’s what I would go with and seen people say that still too much and had to go back to original
Old 06-03-2020, 10:02 PM   #6
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
Just recently got my 4.11/4.10 and true trac broken in and it is a world of deference and that coming from 3.91 craziest part I get better mpg now than I did bone stock.
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 06-04-2020, 09:57 AM   #7
Camarokid1996
Drives: 2010 Chevy Camaro 2ss/rs TF edition
4.10/4.11 gears are THE must have mod for a bolt on M6 car. World of difference when I installed my Motive 4.11's. Yours don't whine at all though? Mine whine more than my ex, especially in 4th and 5th. Not sure if it's my diff bushings causing the sound to travel more or they're not installed properly. Had mine professionally installed
Camarokid1996 is offline   Reply With Quote
Old 06-04-2020, 02:34 PM   #8
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I think I'd end up hurting myself changing gears as i don't drag the car at the track. But if i could hook it sure would be fun lol
Greenhornet2 is offline   Reply With Quote
Old 06-05-2020, 06:07 AM   #9
TommyC
Awesome
I believe 1le and zl1 5th gens and all 6th gen camaro v8 manuals have that insane tall geared transmission. That trans has a HUGE 5th gear so most guys dont want 4.11s because they don’t want to be shifting into 5th at the end of the track. With 3.91 gears the 6th gen guys can do almost 190mph in 5th gear. Thats why they stay away. 5th gen ss camaros are totally different. My 4th gear’s top speed is 128-130 and 5th gear’s top speed is 155-160 now. So with our trans, even if you’re trapping above 130 in the 1/4 mile, that 5th gear isn’t going to kill your time. But you need to be approaching 800 horsepower to even get to 130+mph trap speeds. I think if you go centrifugal supercharged like a procharger, gears would be a great mod to go with it. Itll help you get to to higher rpms to get quicker boost. Just my opinion.
Old 06-05-2020, 06:15 AM   #10
TommyC
That’s exactly what i thought but whats crazy is these gears have made the car a better street car. The 20 inch rims with 3.45 gearing makes this car a 4 speed. With gears, you’re able to keep it in higher gears and accelerate adequately in the street. I do a lot of city driving and i found it to be an absolute pain the way the car bucked. It really is a great all around mod. Not just for drag racing. The best part is now when you do have fun, you’re no longer doing almost 80mph when you shift out of 2nd.
Old 06-05-2020, 07:15 AM   #11
Greenhornet2
Yea but at my power level traction will become even harder. I already fight traction in 2nd with 305's and sticky tires. On a slick at the track yea, but I street drive.
Old 06-05-2020, 05:37 PM   #12
TommyC
My friend who runs 9s launches his car in 2nd gear with 3.73s in a strange 9 inch. Maybe you’ve reached that point too.
Old 06-05-2020, 06:08 PM   #13
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
YES...but 1st gear becomes pretty useless, no traction and really quick shift. I had the ECS Paxton setup on my 2010 w/ 4.10's (DSS 9")...it was damn fun though.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 06-05-2020, 07:28 PM   #14
TommyC
I think it just all comes down to goals. Are you trying to build a fun car to drive in the street or attempting to set records at the strip. I can only imagine how much fun these cars are with that setup. Probably a blast. I plan on doing the ecs 1500 kit with meth in the future but im pretty torn over trying to build a 500+whp n/a setup instead because this is a pure street car for me. Right now full bolt on with 4.11s is seriously fun to kick around town in!
