Old 02-21-2019, 05:18 PM   #1
You Aint Slick
You Aint Slick's Avatar
Drives: 2010 Camaro 2SS
Need Springs for Stock Cam
Long story short, I had a over rev last year on the track, Nothing happened, car runs perfectly, had the valve cover off by a mechanic who knows his stuff, he said the drive train looks good, nothing loose, engine sounds good, no weird ticking etc....
I drove the car for about 1,000-1500.00KM since the event, I also ran twice after pushing the car to the limits and nothing happen.
It's probably safe to say, I dodged a bullet (I think I was riding the clutch, Never dumped it)
However, I want to change the springs when I take the car out, for some peace of mind because it's all I think about, I'm worried I may have overstressed the stock LS3 springs (Yellow Beehives) and future failure is imminent.
I've done my research, and everyone seems to recommend the BTR .660.
I have spoken with them through Facebook Messenger and they said it won't cause excessive wear on the valve train.
Wondering if anyone here runs these springs with a stock cam?
I don't plan on camming the car, just headers, exhaust, intake.
Trying to keep it nice and timid as possible.
Would you guys recommend the .660 Platinum Double Springs?
I talked with my tuner and he said I shouldn't worry, I should leave the stock LS3 springs and worry about other mods.
I just know I'd kick my self in the ass if 1 spring let go, and took the motor with it.
You Aint Slick is offline   Reply With Quote
Old 02-21-2019, 08:01 PM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I would not run too much springs like that on stock cam. I would get a better spring like PSI 1511; look for LazerMontana he has run stock cam at 7200 with it, but he had a free reving 15lbs clutch, not much accessories on the crank, Ti retainers and maybe pushrods.
Bottom line is do not run too much springs, its not a case of "too much is a good insurance". Weak stock cam and harsh springs is not a good idea.
I would run a good light steel retainer for added strength if you put a lot of miles on the car track/street.
FYI I am running thr old TSP 650' springs doubles on my 231 236 640 615 and I want to rev to 7400 and ask some shops for a better springs and got the 660 version of each companies as an anwers. We are not in the same boat by any means...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 02-22-2019, 12:52 AM   #3
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
Lightbulb
Yes unfortunately we still have the stock LS3 camshaft on our 2010 Camaro SS. I installed the Comp Cams Beehive valve springs with the Comp Cams steel retainers for the stock valve stem size. I am able to safety run to 7000-7100 rpm using the stock LS3 camshaft after the tune it has held up very well. If you have to opportunity why not install a very mild camshaft?? I found that there are mild Stage 1 camshafts for sale out there from reputable vendors simpler to the TSP Stage 1 N/A camshaft that put the same to similar wear on the drivetrain. Your LS3 engine will not just self destruct as you are describing. The only way I have seen major damage to the LS3 was from the pushrods or valve stem bending and causing further engine damage. You will not see very good rwhp or rwtq gains from just simple bolt ons like exhaust unless you install at least a mild Stage 1 N/A camshaft. In the near future I would like to install a custom TSP N/A camshaft.
Mr. Clean
Blueovalman is offline   Reply With Quote
Old 02-22-2019, 04:12 AM   #4
Nb1081
Drives: 10 2ss/rs
If you just want some stockers
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 02-22-2019, 07:02 AM   #5
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
PSI1511 with tool steel retainers get some longer push rods. I turned my stock cam 7200 numerous times with miss shifts it seen 7900 lol a valve never touched a piston
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 02-22-2019, 07:26 AM   #6
lazerlemonta
Drives: 2010 C6 1LT
I have done 2 LS3 that made 450 SAE with bolt ons and 1.85 rockers. Camaro went 11.5 @ 120 and the vette went 10.5@131. You can make great power with these things if you just free them up.
Best MPH 134.82
