Emblempros
Old 02-09-2018, 11:14 AM   #1
CGT
Drives: 2011 SSm6
Head Studs
Question for anyone who has installed head studs on a LS3. I'm wondering what was involved, if they were able to be installed before the heads went on, fed through the heads etc? Getting ready to do mine. Thanks
CGT is offline   Reply With Quote
Old 02-10-2018, 01:36 AM   #2
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
You can do one at a time. If that's what you're wondering.
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 02-12-2018, 11:16 PM   #3
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
Set the heads on then install the studs. If you engine in car.
TVS2300,BMR control arms,zl1 toe link,zl1 fuel pump, rotors two piece,Kooks LT headers,high flow cats,corsa exhaust,cradle mounts,Roto Fab air intake,livernois tune tune,washer bottle relocation,ram air,Hennessy wheels, morimoto fogs,DRL harness,coilovers,Installed heads up display,mgw shifter ,slps splitter,slp spoiler,zl1 side
skirts,painted strips,debadged,tinted
lionssfan is online now   Reply With Quote
Old 02-13-2018, 08:25 AM   #4
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Blow out the holes in the block with compressed air 1st.
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.6@145mph
bct10985 is offline   Reply With Quote
Old 02-13-2018, 09:45 AM   #5
CGT
Drives: 2011 SSm6
Thanks guys.
Old 02-13-2018, 09:46 AM   #6
CGT
Drives: 2011 SSm6
I am kind of kicking that around.
Old 02-13-2018, 10:39 AM   #7
Punisher_ATX
Drives: 2010 SS
Thats what im doing. Seems okay lol
Punisher_ATX is offline   Reply With Quote
Old 02-13-2018, 11:08 AM   #8
lionssfan
lionssfan's Avatar
Clean holes
Thanks guys.
You really need to clean the thread holes good. A thread chaser works good or take one of your old head bolts and cut two or three grooves the length wise down the bolt and wire wheel any burrs off. Use this down each hole as many times til there all clean. Use Brake wash and compressed air to clean them out. The idea is you dont want any debris to have any influence on your bolt torque. You tube it will be helpful too.
Old 02-17-2018, 08:55 PM   #9
13ashengrey
13ashengrey's Avatar
Drives: 2013 2SS Ashen Grey
I did mine in the car. I put the studs in 1st then installed the heads. There is way more room than evryone says and yes it's 100% possible. There was no fighting around anything either. Make sure the holes are cleaned out as stated above.
13ashengrey is offline   Reply With Quote
