06-15-2016, 12:24 PM | #1 |
Drives: 2017 ZL1, A10, White, sunroof, nav Join Date: Apr 2009
anyone had a problem with 2013 HUD fading to nothing?
Driving down the road today and all of a sudden no HUD???? Turned it off and back on and it was on for a few seconds then dimmed to nothing...tried again...same....tried yet again and it wouldn't come back up...hmmm
Left it parked and car off for several minutes, started it up and all seemed fine....didn't run it long though, had to get back to work. Anybody experience anything like this? Possible glitch? 32K miles and don't remember this happening before. I do keep the dash logic plugged in, however it didn't seem that it played a part in this as I had it out and it happened too. Thanks in advance for any input. |
06-15-2016, 12:27 PM | #2 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
I had the backup camera screen go white. Shut car off and sat for awhile. Started back up and worked fine. I am guessing software reset. Yours might be same.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
06-15-2016, 01:17 PM | #3 |
Let's go fishing!
Drives: a car with 8 cylinders Join Date: Apr 2016
Sometimes your MyLink misses automatic updates and the dealer will need to do it for you. It's crazy how everything can be interrupted by MyLink...
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
06-15-2016, 01:52 PM | #4 |
Sarcasm loading --------
most likely bad HUD control switch.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
06-15-2016, 03:30 PM | #5 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
There is a history with failure. The bummer is they have to remove the dash to get to it.
http://www.camaro5.com/forums/showthread.php?t=296162 |
06-15-2016, 09:31 PM | #6 |
Drives: 2013 ZL1 A6 #4801 Join Date: Mar 2016
Mine did this once when I drove it for a while and it was a hot day. Turned it off, and next time I drove it, it was fine. 17K miles and still under extended warranty. Seems to be fine, and it hasn't happened again. Even if it does, there's no way they're tearing my dash apart to fix it.
06-15-2016, 11:28 PM | #7 |
KaBoom1701
I would contact Ofer and do the color HUD upgrade.....
http://www.gen5diy.com/Chevrolet/Cam...-HUD-Upgrade4/
Mods:
06-17-2016, 02:21 AM | #8 |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
Never had an issue with mine. Bright as its ever been.
06-17-2016, 08:31 AM | #9 |
Thanks for the responses guys.....it has been working just fine since the original "incident". I will be keeping an eye on it though! lol
I guess Sven59 may have been right! |
06-23-2016, 06:07 AM | #10 | |
Drives: 2013 2LT/RS BRM convertible Join Date: Nov 2015
2013 2LT/RS BRM Convertible |
07-14-2016, 09:34 PM | #11 |
Mine has done it periodically on my 13, but the dealer cant replicate it, and lately I havent either. Probably happened a DOZEN times. It seems if i toy with moving it up and down, and or adjusting the brightness it does eventually come back. Wish there was a TSB or some documented cases that can help me diagnose and repair. HOPEFULLY it doesnt need a new HUD, but if so, I'm going color!
07-14-2016, 10:03 PM | #12 |
My 13 1LE has done it several time since I got it, the exact same thing. Dealer also cannot reproduce it. It seems to happen every six month to a year. Now I am out of warranty and I don't know what I would do if it happened again.
07-14-2016, 11:11 PM | #13 |
Mine did this once, a year or so ago. Starting working again after turning car off and waiting a few minutes. Been fine since.
07-15-2016, 04:02 AM | #14 |
I used to have a 2013 2LT/RS and had the same problem periodically. Have not had the problem with my 2014.
