03-13-2012, 01:25 AM | #1 |
Drives: Black 2SSRS Join Date: Nov 2011
Which cam to choose
I have a 2010 SS L99 and Im looking into getting a cam. Just trying to find the best one out there. I know there are many different ones and any ideas/help would be great!
03-13-2012, 01:47 AM | #2 |
Drives: 2004 GTO Join Date: Feb 2012
Need more information, what's it's intended usage? Where do you want your power to be in the rev range? Do you plan on doing any sort of f/i in the future? You have an auto or manual?
03-13-2012, 01:50 AM | #3 |
Its an auto. Really looking for a cam to add some power and give it a nice sound and Im not to sure about adding any f/i anytime soon
03-13-2012, 02:27 AM | #4 |
Drives: 2010 2SS/RS LS3 A6 Join Date: Mar 2011
I'm doing the same thing and did a lot of research and reading. If you want bad ass sound, numbers and nothing but good feedback, go with the Texas Speed cam 231/236 with and LSA of 112. I have an L99 and won't be doing any FI for awhile either. The other popular one is the LG Motorsports G6X3. The LG cam is a little to lopey for my taste but the TSP cam that I'm installing this week I feel will perform and sound amazing. I will be adding a vid to my build thread when it's all done. My blog is in the Member Journals section under "Ken's NA 2010 A6 build. Check it out and good luck!
Oh, one more thing. You'll want to do a DOD/AFM delete on your car. Trust me, it's worth it. Get rid of that fuel mgmt stuff. Your car will run and sound better. Plus you have to do that to use these cams. Here's a link: http://www.texas-speed.com/p-79-texa...-camshaft.aspx
03-13-2012, 02:32 AM | #5 | |
Here is a video of the TSP 231/236 cam idling..
03-13-2012, 07:46 AM | #6 |
Drives: 2011 Camaro SS/RS Join Date: Feb 2011
03-13-2012, 08:07 AM | #7 |
No Tags/Habitual Violator
Keep in mind the more radical cams like a higher stall converter.
It would be helpful to hear from anyone that has put some miles on a cammed L99 including converter info. SoCo |
03-13-2012, 08:53 AM | #8 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
You need a stall converter for a cam that big, gears would help too. The bigger you go the less down low you have and more power up top. Keep that in mid when choosing... you could run a smaller cam on a tight LSA for a bit more chop at idle. Personally I think most of these cams are too big for this car without the proper gearing and converter.
10.91 at 122 H/C stock block N/A
03-13-2012, 12:19 PM | #9 | |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
I agree.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
03-13-2012, 12:22 PM | #10 | ||
It will sound exactly like this one.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 03-13-2012 at 02:07 PM. |
03-13-2012, 02:01 PM | #11 | |
03-13-2012, 02:09 PM | #12 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
Feel free to give us a call here at Lethal Racing. We are also close to you, in lafayette. We have a few cam choices that I think would intrest you. One of them doesnt require a converter.
Thanks, Nick |
03-13-2012, 02:38 PM | #13 |
Drives: 2011 Dodge 3500 dually Mega Cab Join Date: Jul 2009
I will throw the VVT-3 cam in as an option, but does require a converter. It makes good power and backs it up at the track.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
03-13-2012, 03:24 PM | #14 |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
OP, contact a vendor... your question is still vague. All will give you power/sound, some will give you much more than you want and will suffer low end. VVT cams will give you low end, but while reliable so far..don't have much of a proven track record yet with an L99,
prepare to dump around 3-4k after parts, labor, tune that does not include supporting mods like trans coolers or torque converters. If you go big, you will def want a torque converter.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
Similar Threads | ||||
Another L99 cam question....VVT! | SS-screamer | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 91 | 12-27-2022 11:28 AM |
Vengeance Racing Cam Kit Plus!!! L99 Conversion Package!!! American Racing + Vararam | Kevin@V | Engine Internals | 25 | 11-16-2011 10:14 AM |
Vengeance Racing Cam Kit Plus!!! L99 Conversion!!! American Racing + Vararam | Kevin@V | V8 Bolt-Ons & Tunes | 19 | 11-02-2011 08:40 AM |
VVT Cam Specials! | yyz28 | Engine Internals | 17 | 10-18-2010 11:29 PM |
Cam Headers Intake Tune 446 RWHP 430 RWTQ | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 72 | 11-25-2009 03:09 PM |
