10-12-2022, 12:22 PM | #1 |
Drives: 2014 Camaro SS Join Date: Feb 2022
The Redheaded Stepchild
Picked up this super clean low mile 14 2ss back in March. Most of the mods were already done but I've added some touches here and there. Will update this thread as I add more.
As purchased mod list - 2014 Camaro 2SS SBE L99 D1SC Procharger Yank 3800 PAS convertor ARP head studs Custom boost cam/DOD/VVT delete Stainless works headers & mid pipes Magnaflow axle back Fore dual pump fuel system Fore FC3 controller FIC 1300cc injectors BMR springs 1le wheels ~600 rwhp New additions - Tru-cool 40k trans cooler Forgestar d5 17×10/18×8 wheels Nitto 305/45/17 DR's BMR poly cradle/diff bushings BMR non-adjustable trailing arms Smaller pulley + retune for added boost Carlyle 15" brake kit BMR Xtreme Anti-roll Bar ~750 rwhp To come - BMR rear drag suspension kit Racestar 15×10 wheels wrapped in 275/60/15 Hoosier DR2's Best dragy pass with 17" ET streets on the old setup - 7.43 @ 101 and 1.90 60' in -400 DA Best on current setup - 7.15 @ 101.1 (ran out of room and got on the brakes about 50' early) and 1.84 60' on Nitto DR's in +9xx DA Those numbers are on unprepped Mexican streets, no burnout, just stop and stomp. Took it to the track once on old setup (minus the wheels/tires) and went 7.44 @ 96 2000+ DA with a 1.75 60' and wheelhop city. Hoping to go mid 6's on the new setup once I get everything together. As she sat when I got her - Last edited by 78novacaine; 01-09-2023 at 09:02 AM. |
10-12-2022, 12:26 PM | #2 |
As she sits now with a little over 15k on the clock -
The pile'o'parts in my foyer - |
10-12-2022, 01:55 PM | #3 |
Drives: 2010 ABM Camaro SS M6 Join Date: Jul 2020
Very nice!
10-12-2022, 06:42 PM | #4 |
1000hp is NEVER Enough!
Awsome!
Cannot wait to see what you have in mind for your little red wagon!
1,000hp IS NEVER ENOUGH!!!
10-13-2022, 06:04 AM | #5 |
10-13-2022, 06:06 AM | #6 |
Looks very nice!
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
10-15-2022, 02:04 PM | #7 |
Thank you sir!
Today's round of mods, added the Carlyle 15" brake kit and BMR anti-roll bar. That bar is a BEEFY piece compared to the stock sway bar. Install went pretty smooth with only a couple minor hiccups. I'll need to reroute the brake lines to clear the 15" wheels but I'll do that when I install the new LCA's and coilovers. Test drove to bed the brakes and made a couple hits. Everything feels good and tight as it should be, no extra noise or vibration to speak of from the new sway bar. Old vs new: Installed: |
10-25-2022, 07:04 AM | #8 |
Well everything was going great until it wasn't. Made a couple pulls on my way to work the other day, hit a new best mph of 106.5 with the cooler air, nothing seemed amiss. Started the drive home and coolant temps were a little wonky, then rapidly spiked up to 240 before I could pull over and they dropped again. Let it cool off soon as I got home and opened the radiator. Sure enough, missing coolant + oil in the rad. Pull the plugs and find oil on #7. So all but confirmed blown head gasket, I'll be slowly pulling it apart in what little free time I have over the next few weeks and hope it was just a gasket failure.
10-25-2022, 10:52 AM | #9 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Bummer man, hopefully you get her sorted out quickly and nothing major was damaged. Sounds like you stopped the car just in time to prevent any real damage though.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
10-26-2022, 10:18 AM | #10 |
I'm hoping so. I definitely need to figure out if it was just a freak failure or if there was a root cause before I throw it back together and have it happen again. Hopefully once I get the heads off everything in the valvetrain and elsewhere looks solid, but that won't be for a couple weeks at least.
11-14-2022, 09:10 AM | #11 |
Not much to update here. Dropped the heads at the machine shop to get resurfaced and the valves redone (had a busted seal on #7).
Taking care of some other odds and ends in the meantime. Wiring on the o2's was burnt up pretty bad on both sides so got new sensors/extensions to go in. Oil "cooler" had a small leak so went ahead and got everything I needed to delete that, and took off the front swaybar since I'm setting the car up to be a straight line warrior. New gaskets all around, and upgrading to some 1200 or 1300cc injectors when she goes back together. !A bunch of crap I don't need, lol - |
01-03-2023, 06:01 PM | #12 |
Got everything back together and fired up finally. Had a couple minor issues (wiring and such) that I don't have the time/expertise to track down and repair, so it's at a friend's shop for that and he is going to throw in some 1300cc injectors while it's there. After that it goes to Pat G for tuning. Dropped it off yesterday, hoping to have my girl back and tip top in just a couple weeks now!
01-04-2023, 04:06 PM | #13 |
I know its not the best of circumstances, but that's a really cool photo! I hope your friend is able to work out all the gremlins for you.
01-05-2023, 01:54 PM | #14 | |
Got good news this afternoon, the car is 100% buttoned up mechanically and will be heading to the tuner tomorrow morning! |
