#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
Old 07-15-2020, 11:35 PM   #1
booyaa56
booyaa56's Avatar
Drives: 2017 Camaro 1LE
Need help choosing offset for 19x11 front wheel for 2017 SS 1LE
So I’m going to order a 19X11 front wheels just need help with the offset that will allow me to clear the strut with max camber. Any help would be appreciated
booyaa56 is offline   Reply With Quote
Old 07-16-2020, 12:38 AM   #2
samr350
samr350's Avatar
Drives: 2017 SS 1LE
Well a 19x10.5 et22 needs a 5mm spacer to clear so do the math from there. However if you're going to run camber plates instead of getting the camber from the adjustment at the knuckle there's a good chance you might not need the 5mm spacer at all as increasing camber at the knuckle reduces wheel to strut clearance.
samr350 is offline   Reply With Quote
Old 07-16-2020, 02:25 AM   #3
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
The ZLE uses 19x11 et11 front wheels. But the strut is a bit smaller in size and the mounting ears for the knuckle are longer providing more clearance.
You will have to grind the strut mounting ears for clearance anyways just to fit the 19" wheels. You might be able to get away 11mm offset with -2.5* but it would be close.
I run -2.7* with 19x11 et11 and camber plates and minor strut ear grinding.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 07-16-2020, 07:01 PM   #4
booyaa56
booyaa56's Avatar
Thanks for the feedback
Old 07-22-2020, 01:42 PM   #5
tmalaquin
Drives: Blue ss 1le 18
I run 19x11 ET11 Apex wheel up front and I could get -2.7 deg camber with no grinding, I used a 3mm spacer.
tmalaquin is offline   Reply With Quote
Old 07-22-2020, 07:54 PM   #6
booyaa56
booyaa56's Avatar
tmalaquin
Thanks for the info I have both 3mm and 5mm just in case
Old 07-24-2020, 04:29 PM   #7
Dads1le
Drives: 17 ss1le. Pray headcam e85 fbo msd
I run 19x11 et11 up front with no spacer and moderate grinding on strut with no camber plates -2.7 camber. No issues on track or autox
Dads1le is offline   Reply With Quote
