03-08-2023, 05:51 AM | #1 |
Banned
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
Loose feeling rear end.
A few weeks ago I was doing some spirited driving for ‘reasons.’ Initially I was in Sport mode. I noticed that hard lane changes at speed were giving me a bit more rear end wiggle than I’ve experienced in the past. Basically a bit of left to right wiggle after the change. Nannies were on. The last time I did any high speed runs I was on stock Goodyears, this time I had all seasons on it. Switching to Track damped it down a bit but it still felt less connected than I remembered.
Tires? Or just faulty memory on my part. I’ve heard of swapping some ZL1 bushings out for improved performance, but I don’t know exactly which ones and if that might improve rear end stability. |
03-08-2023, 06:44 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I get it in my car there's a thread on it but basically no one knows why or how to remedy it. Most thoughts go to the e-Diff doing it's job. It's unsettling though.
03-08-2023, 06:50 AM | #3 | |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
03-08-2023, 07:56 AM | #4 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
03-08-2023, 09:20 AM | #5 |
Drives: 2022 Camaro 2SS 1LE Join Date: Jul 2022
I Chuckled at the thread title, but then again i've got the brain of a 12yr old.
03-08-2023, 09:25 AM | #6 | |
Banned
03-08-2023, 09:25 AM | #7 |
Drives: 2023 2SS 1LE Join Date: Dec 2022
Tires will make a big difference in feel. If this was your first comparison with spirited driving in the new tires. Different compound, different tread, softer sidewall. Going from the stock tires to an all season as posted above, will make a massive difference. Try to mess with the PSI of the tires too, that could help a bit getting a bit of control back from the rear end.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold- 2016 Grey Chevy Volt -Sold- 2018 Blue AWD Kia Stinger GT2 -Sold- |
03-08-2023, 11:21 AM | #8 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
It's the tire change. There's no way the cradle bushings are playing a part here with the amount of loading the chassis is seeing on the street. Especially on the less grip tires.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
03-08-2023, 11:45 AM | #9 |
Tires are a thing but Ive had this on two Camaro's with OE SC3's in the dead of summer.
03-08-2023, 12:38 PM | #10 |
Drives: Camaro 1ss Join Date: Nov 2019
I would say it's a combination of both tires and the rubber subframe bushings.
I just installed the ZLE solids in my rear end. It's not that hard of a job. I did it with the subframe pretty much in the car yet. Check out my build thread for pictures of the install. https://www.camaro6.com/forums/showthread.php?t=613004 https://www.camaro6.com/forums/showthread.php?t=613004
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
03-08-2023, 12:39 PM | #11 |
Also when was the last time you got an alignment?
Rear toe doesn't hold for shit in these cars. messed up toe alignment can also cause what you are mentioning.
03-08-2023, 01:05 PM | #12 |
Banned
Thanks for the responses. I've thought about getting another set of rims for summer tires. It may be time to pull the trigger on that and to get a 4 wheel alignment.
03-08-2023, 02:00 PM | #13 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Technically you are supposed to replace 4 rear bolts whenever you get an alignment so you should buy those and bring them with you if you do get an alignment. It is also not a bad idea to find and print the torque specs for these bolts to give to the tech to make sure they tighten them enough.
https://www.camaro6.com/forums/showthread.php?t=502324 I agree with others that it is likely the tire switch that caused your issue. If the alignment is badly off you should see uneven tire wear or the car should pull to one side. |
03-21-2023, 09:55 PM | #14 |
Hotchkis front sway did the trick for me
