03-26-2011, 01:39 PM | #1 |
Drives: 2010black on black camaro ss auto Join Date: Jan 2011
Help guys ses light after jba catted midipe install
Just pulley car off rack install went perfect did not use o2 bung extensions on bak sensors drove car for ten minutes and thru a light !! How do I reset and how can I fix this if it continues cause these things sound Frikn wicked as he'll thru the maganaflow catbak I have ?????? Help dude
03-26-2011, 01:50 PM | #2 |
Come on someone help me out wouldn't have spent 400 dollars on these if I new they would throw a code ! Chime in guys please
03-26-2011, 02:09 PM | #3 |
Can anybody help with this problem???
03-26-2011, 03:00 PM | #4 |
I had trouble reading your post since most of it wasn't english. Did you say you did not put the rear O2 sensors back in, or just the extensions? My guess would be you have a cat inefficiency code. You may need to give people more than an hour to respond. I know your freaking out right now.
I will also give the standard response to most of these issues. "Double check the wires and connections." |
03-26-2011, 03:41 PM | #5 |
1,425 hp / supercharged
Drives: (2010 2SS/L99) (1999 Corvette) Join Date: Oct 2009
Are you still using all four O2 sensors? If not, you're going to need to tune out the ones not in use.
"If it's too loud...well, you know the rest."
03-26-2011, 04:25 PM | #6 |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
tune it and say good bye warranty coverage...unless GM service center can reset the code? haven't come across them doing that yet...
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
03-26-2011, 04:39 PM | #7 | |
He can reset the code with any hand-held tuner or OBDII, but if he's only using two sensors, it's just going to come back on again.
03-26-2011, 04:40 PM | #8 |
i dont know i put mine on a few weeks ago and i have no lights, runs great.
double check that you have all 4 o2 harnesses plugged back in.
03-26-2011, 04:46 PM | #9 |
It has all four o2 sensors just like stock reset commputer stil comes on
Also checked all sensor wires. |
03-26-2011, 04:51 PM | #10 | |
What code are you throwing?
03-26-2011, 06:32 PM | #11 |
Silcone hmm I used grey anti seeze grease ??
03-26-2011, 06:34 PM | #12 |
I reset it with a handheld yet only unhooking battery and tried that way came bak on after a few minutes ! I am running all four 02 sensors , stock manifolds with jab catted mid pipes !
03-26-2011, 07:18 PM | #13 |
At this point, you really need to find out what code your throwing. Some anti-seize compounds are silicone-based, and that stuff will definitely kill an O2 sensor when it burns. If you don't have an OBDII or hand-held tuner, take it to Autozone or Advance. They'll scan it for free.
If it turns out your code is for one or more of the sensors, I would replace them with Denso sensors. They claim they're silicone proof, and I've always had good luck with them in the past. They're not cheap, though.
03-26-2011, 08:07 PM | #14 |
Ok thanks a lot sure hope it's somthn simple ,the dumb ass at the exhaust shop is the one who used the anti seeze shit!! Didn't wanna mod the damn car after the cat bak but wanted more sound so I did these and now my luck I have issues..
Similar Threads | ||||
Alternative way to install dashboard ABL (with light tape) | FIREWOLFF | Cosmetics and Lighting Modification Discussions | 96 | 04-27-2014 02:24 PM |
How do you remove and install fog light fixtures in new camaro | Aristomones | Camaro DIY & HOW-TO instructions & discussions | 18 | 04-04-2014 04:19 PM |
Strobe flashing SES light HELP | 2ndgenz28 | 3rd Generation Camaros | 2 | 03-12-2010 02:25 AM |
Some Texas Lighting Laws | Mecha | USA - Texas | 5 | 10-20-2009 01:49 PM |
DIY: Here it is Dashboard ambient lighting ABL | Tecca | Camaro DIY & HOW-TO instructions & discussions | 356 | 09-03-2009 10:46 AM |
