02-16-2013, 09:41 AM | #1 |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
Manual Tranny 2nd Gear ???
I am hopefully purchasing a '13 LT so a few questions if I may.
Do the manual transmissions in the v6 cars have the same 2nd gear grind problem as the v8 cars? How big is this problem I have seen a few complaints on here but seems to mostly be in v8 cars. Is it the same transmission in both cars? Is this still a problem with the 2013 model year cars or was it only on earlier cars? Have any of you had to take your car in for warranty repairs because of this problem? Were they able to fix the problem? Thanks for all your help cady |
02-16-2013, 09:59 AM | #2 | |
Drives: Camaro SS Join Date: Aug 2011
02-16-2013, 10:03 AM | #3 |
Robs SS
The ss second gear problem is a synchro blocker ring problemi had mine done under warranty now it works great
[COLOR=lime]my kinda going green POWER 605 RWHP powered by maggie chrome tsv 2300 supercharger,ar long tube headers high flow cats b and b exhaust ,roto fab intake ,lingenfelter cam , upgraded sc reservoir ,Comp cams
performance valve springs, Comp cams Titanium retainers,Heavy duty valve locks,MSD ignition wires, Kool Sox heat resistant heat sleeves , Larger fuel injectors, high flow fuel rails,American racing rims ,hurst short throw shifter,led footwell and grille lighting,pfadt suspension upgrades |
02-16-2013, 10:35 AM | #4 |
Trading in the SS?
02-16-2013, 11:00 AM | #5 |
Drives: 2012 camaro Join Date: Feb 2012
never ground a gear in my V6MT
02-16-2013, 11:29 AM | #6 |
It's in the hole!
02-16-2013, 11:37 AM | #7 |
Drives: IOM 2012 1SS m6 Join Date: May 2011
2012 shifts just fine. Never a grind even with pedal to the metal
02-16-2013, 12:11 PM | #8 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
No problems here either.
02-16-2013, 02:31 PM | #9 |
No problems on my '11 V6.
02-16-2013, 03:41 PM | #10 |
Drives: 2012 2LT Join Date: Jun 2012
No grind for me either
02-16-2013, 04:13 PM | #11 | ||
02-16-2013, 05:33 PM | #12 |
Drives: 2011 camaro ss2 I.O. M6 Join Date: Nov 2012
Congrats on Your new LE, I am jealous, I have a 2011 2ss and it has the stupid grinding problem. It happens occasionally.
Posted from Camaro5.com App for Android |
02-16-2013, 05:45 PM | #13 |
Jordan
Drives: 2012 Transformers Edition 2SS/RS MT Join Date: May 2012
I have 2nd gear grind problem. Car is not daily driver, '12 2SS/RS TF3 Edition, 1 Year Old, Less then 9800 miles on odo, I'm only owner, meticulously maintained, when temperature is below 55 on tranny grinds like a mother***** in 2nd until +80F. Will bring in for warranty when no salts on roads. Never seen rain, snow, salt, or extreme heat or cold Garage kept ftw.
02-16-2013, 05:53 PM | #14 |
Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
I have gotten 2nd Gear Grind on my V6. It only happens when Speed Shifting
