05-30-2011, 09:00 PM | #1 |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
E-Force Heat Exchanger Design Flaw?
I noticed on my E-Force that the inlet on the heat exchanger is on the top left and the outlet is on the bottom right. Since the E-Force cooling system runs with no or very little pressure, it seems the coolant flow through the heat exchanger would not be uniform. Thus, reducing it's cooling effectiveness.
I would think the inlet/outlet locations should be the exact opposite for a cross flow heat exchanger design. It seems to me the most effective design for a SC heat exchanger would be a down flow design with the inlet centered at the top. Anyone familiar with fluid dynamics knowledge out there that can shed some light on this? |
05-31-2011, 07:52 AM | #2 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
Most serpentine cooling coils are cross flow with inlets at the lower, leaving air side and outlets on top, air entering side. This creates desireable "cross flow" and also allows air bubbles to leave the coil and not be trapped inside. Cross flow is optimal because it has the highest net difference in temperature between the air and the fluid at all times as the air passes through the coil which creates the highest possible heat transfer(most efficent). If it is only a single pass and not a serpentine then you cant have "cross flow" as it all goes by at one time.
-Mark. |
05-31-2011, 01:10 PM | #3 | |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Watch this video of an E-force:
If anyone hasen't seen the video of this in use, watch this: Here is a video of the C6 corvette version: |
05-31-2011, 03:44 PM | #4 |
Similar Threads | ||||
The mighty LSA supercharged V8. | Mr. Wyndham | Camaro ZL1 Forum - ZL1 Specific Topics | 137 | 05-07-2011 10:05 PM |
Popular Mechanics Best Vehicle Design Award: 2010 Chevrolet Camaro | ShnOmac | 5th Gen Camaro SS LS LT General Discussions | 39 | 12-02-2009 12:49 PM |
Rebuttal Letter from Ed Wellburn regarding GM's design direction | GTAHVIT | 5th Gen Camaro SS LS LT General Discussions | 65 | 06-13-2009 08:04 PM |
Gap between windows--possible design flaw? | fldrummer | 5th Gen Camaro SS LS LT General Discussions | 38 | 06-05-2009 10:26 AM |
2009 Chrysler 200C Concept | Muscle Master | General Automotive + Other Cars Discussion | 27 | 04-26-2009 06:03 PM |
