02-28-2016, 06:35 PM | #1 |
Drives: 2013 Camaro 2LS Join Date: Oct 2015
P2128
yesterday i was being curious about the pcm/ecm plugs and unplugged the one with the blue tape. when i got it back in and turned the car on it said reduced power and service stabilitrak. i tried disconnecting the battery, replugging in the cord, clearing the code, reloading my tune and making sure everything else around it was plugged in and nothing helped. i saw that P2128 was throttle position so i checked my throttle body and it is not 100% vertical. the top faces you and the bottom faces the manifold like this \ from a side view. im not sure if that has anything to do with it but i also disconnected the gas pedal and im not sure where to start on it if it needs fixed. i had no problems prior to pulling the plug with the blue tape on the ecm. Any advice is appreciated
2013 2LS - K&N CAI, Overkill Ported 80mm Throttle Body, Overkill E85 Kit and Overkill Tune, Jacfab Ported Intake Manifold and Spacer, Stealth 3.0 TC, ARH Catted Downpipes, Magnaflow Resonated X-Pipe, Resonator Delete, Jones Full Boar Racing Mufflers, BMR 1.2" Lowering Springs, Elite Engineering Catch Can and Clean Side Seperator
Thread Tools | |
