03-16-2017, 07:23 PM | #1 |
Drives: '17 LT 2.0T AUTO Join Date: Aug 2015
Shift Points on the 8-speed Auto
So, just picked up my 2017 2.0t with 18 miles...WooHoo. I've owned quite a few Camaro/TA in the past.
Once the 1.500 mile break-in passes, am thinking about the Injen EVO7300 intakes. One of its benefits is bringing peak power to 6k (not just the 5.6k) However, where does the car shift when you floor it ? If the car shifts at 5,600 there's a loss of benefit there for me. Thanks all ! |
03-16-2017, 11:01 PM | #2 | |
Drives: 2016 2LT RS Blue Velvet Join Date: Dec 2016
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake |
03-17-2017, 07:50 AM | #3 | |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
I literally never drive in Auto mode, always manual shifts for me. I like the control and I don't like being in 7th gear going 30 mph. Plus... I like downshifting EDIT: I have the Evo7300 and I love it. If you are looking for more blowoff noise, go with the open Injen CAI and not the 7300. Both look great and perform great.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
03-17-2017, 10:37 AM | #4 | |
Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
I wouldn't consider 6200-6300RPM @ WOT to be an early shift. I'm assuming you're talking about part throttle shifting? |
03-17-2017, 01:07 PM | #5 |
From the videos I've see with the auto 2.0T, I've seen basically all the WOT upshifts at 5500-6000 RPM. Like I said, I don't own an auto, so I haven't experienced its behavior, and I'm only basing my information from what I have seen.
03-17-2017, 01:44 PM | #6 |
Tach lag is an actual thing. I'm basing my estimates off data logs.
03-17-2017, 07:02 PM | #7 | |
2016 Camaro 1LT 2.0T
Drives: Nemesis Join Date: Feb 2011
I use to drive conservative with the manual until I learned that I can still get 27/28 mpg by staying in the power band around 3k rpms. I've got so used to it that I can't stand driving conservatively anymore because of the lag. |
03-19-2017, 09:15 AM | #8 | |
Pat
03-20-2017, 11:02 AM | #9 |
Great Information !
Appreciate it ... |
