03-09-2020, 11:30 AM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Boost gauge question
Hey guys, so where is the best spot to tap into the system for a boost gauge? 15 camaro ss. Was thinking of just drilling and tapping the intake manifold, but was curious if there is a better way. Thanks
03-09-2020, 01:34 PM | #2 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
Just T into an existing vacuum line. like the one on the side of the throttle body.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
03-09-2020, 03:29 PM | #3 |
03-10-2020, 01:55 PM | #4 |
Drives: T Join Date: Mar 2015
or you could add a vac block to your brake booster and run what you need
03-13-2020, 10:34 AM | #5 |
I ended up using the extra port on the back of the intake, beside the brake booster outlet
