Old 05-11-2011, 11:46 AM   #1
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
LS9 rotating assembly in an LS3?
OK, I've done a little checking and based on my research... which isn't a whole lot... it looks like the Crank, Rods and pistons from the LS9 would be a direct replacement for the LS3...
OK. So we all know the LS3 heads flow pretty well. Is it recommended to go with the LS9 internals on a stock LS3 block????
IF so, would it be worth it???
is there a better aftermarket option out there? Am I even making any sense at all???
Tuners, sponsors and members please share your thoughts on this.
I'm thinking I might learn a few things from this discussion.
Old 05-11-2011, 12:58 PM   #2
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Have you looked into buying a shortblock. There are some companies out there that are making a really good product very reasonably priced...
I'm not really biased, but I do know that you can get a forged balanced blue printed LS-3 sleeved block from ERL for less than 4 grand...
There are some options for head studs etc... Those are all a personal choice... You know the power I'm putting down and other than cooking a turbo for what ever reason, I've had no issues so far... Time will tell on that of course... though they say that a motor with big power will fail pretty quickly if there is a fault.... and yes, I've pushed mine really hard already, though it is on a very conservative and safe tune...
As for the LS-3 heads, I know they have the capability to flow at least 390 CFM... Ask me how I know...
Just asking...
Old 05-11-2011, 01:15 PM   #3
GTAHVIT
Blessed
GTAHVIT's Avatar
I'm really just thinking out loud here.
At some point a while from now, I'd like a bullet proof ( as much as that is possible and affordable ) 700RWHP build.
I'm just wondering about the feasability of using the LS9 internals or if anyone would even consider it?
Old 05-11-2011, 01:34 PM   #4
paul2010
paul2010's Avatar
Drives: 2012 ZL1 #1278
For the price you could probably build better cheaper. Also the LS9 heads are much better. From what I understand LS9 ported heads you can run more timing and get much better flow then LS3 ported heads.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout
2011 2nd Place Fastest 4 5th Gen LSX Shootout
paul2010 is offline   Reply With Quote
Old 05-11-2011, 01:42 PM   #5
full of days
full of days's Avatar
Drives: Camaro GT
GMPP catalogue has the race top end with flowed & ported head which would work fine on a stock LS3 bottom end. I'm building a NA motor & not going with a blower or turbo However as 700 hp causes lots of things to break & is not good for the bank account as you will always be fixing broken parts...
Post Tenebras Lux
full of days is offline   Reply With Quote
Old 05-11-2011, 02:16 PM   #6
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
LS9 rotating assembly = BIG $,$$$. Titanium rods, forged crank, forged pistons, new flywheel for crank, etc. You can build a strong enough motor just by swapping to aftermarket forged rods and pistons... of course while you're at it a stroker crank is a cheap upgrade when rebuilding the shortblock. The factory crank will handle 700+ hp all day long though.
Irnwkrkev is offline   Reply With Quote
Old 05-11-2011, 03:11 PM   #7
GTAHVIT
Blessed
GTAHVIT's Avatar
I hadn't thought about the flywheel... I did like the idea of Titanium rods... but I guess that might be overkill for what I'm thinking... I was pretty sure the stock LS3 crank would hold up but wasn't sure. So... maybe LS9 heads????
Again, I'm thinking there are just as good or better aftermarket heads for less money???
Old 05-11-2011, 03:27 PM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Does PQ know about your latest premonition...:emoticon7:
Old 05-11-2011, 03:55 PM   #9
GTAHVIT
Blessed
GTAHVIT's Avatar
OH dude, this is so far down the road... He's got nothing to worry about...
Old 05-11-2011, 07:15 PM   #10
Slowhawk
Drives: 1999 Trans Am
A forged shortblock from a sponsor will be cheaper and stronger. Titanium rods are not the strongest out there.
Slowhawk is offline   Reply With Quote
Old 05-12-2011, 03:55 PM   #11
Hess Motorsports
Drives: 2010 SS with WAY TOO MANY MODS
Hey guys..... I hate to burst your bubble but converting to LS9 isn't that simple or cheap. yes the parts are similar for cubic inch but that is where it all ends. Don't foget the LS9 has a 1.5" longer crankshaft snout to drive the two oil pumps for the partial dry sump AND for the larger 6/11 rib drive belts. Whcih means you will have to buy all LS9 timing components, front cover, water pump, accesories, A/C system, power steering components, a dry sump pan, AND build a custom oil reservior.
The job is a complete nightmare (we just finished a complete LS9 conversion including blower) and the misc parts required to complete it properly put the job cost well over the point where it would be worth it to 99% of customers.
For the money, use the new Darton sleeves (stronger than LSx block AND, you can keep the weight down and better cooling), port your heads, run a ZR1 cam, stroke it out to 434CID and toss forced induction on it. There is an easy 1000hp recipe that makes sense
Hess Motorsports is offline   Reply With Quote
Old 05-13-2011, 12:38 AM   #12
Caliman93230
Caliman93230's Avatar
Drives: LS3S/C
What would a 418 forged cost labor included, thinking about doing this soon
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
Caliman93230 is offline   Reply With Quote
Old 05-13-2011, 08:29 AM   #13
GTAHVIT
Blessed
GTAHVIT's Avatar
Just for a point of discussion..
Like we've mentioned above,
What about on the stock LS3 crank??? does it make sense to go with LS9 rods and pistons?
Old 05-13-2011, 10:00 AM   #14
Caliman93230
Drives: LS3S/C
i would like to know what parts are essential for a forged ls3 and what stock parts I can keep,
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 12:30 PM
LS9 Cam in a NA LS3 Commit and Conquer V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 15 01-04-2011 10:30 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
LS3 vs LS9 BumbleDs Forced Induction - V8 9 10-02-2009 09:27 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
