11-07-2014, 04:01 AM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
four tires & wheels fit inside car in backseat area
I have been struggling with an easy method to transport my road course tires and wheels and wanted to try removing the backseat and see what fits. To my surprise, all four wheels/tires fit with room to spare straight across in the backseat area. Removing the backseat is a 10 min job so don't worry about it. The seat cushion just lifts up off its two front and rear clips. The seat back is retained by one central 18mm nut and 4 15mm screws on the sides. Here is a pic of them ready for the trip to VIR this weekend. My tires are 285/35-20 Toyo Proxes on a set of cheap wheels(no lighter than stock).
11-07-2014, 05:37 AM | #2 |
Interesting. Difficult though with a cage or harness bar. I am honestly considering adding add a hitch to the car for the next season
11-07-2014, 05:42 AM | #3 |
Drives: '16 C7 Z51 Join Date: May 2012
GM engineers wanted to remove back seats from the Z/28, but realized the seats add quite a bit of rigidity, and a cross bar would not be any lighter.
Long story short, you're losing precious body rigidity.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
11-07-2014, 07:28 AM | #4 |
Here is an exerpt from the GM press release concerning the rear seats in the Z28...
"The rear seats of the Z/28 have also been modified for weight reduction. A total of nine pounds (four kilograms) was saved by eliminating the seat-back pass through, as well as using high-density foam in place of the rigid structure of the seat back and steel mesh of the seat bottom." "Quite a bit of rigidity"...I doubt it. A harness bar could easily be bolted in position for track days and removed quickly for transportation. I have used a hitch and cargo carrier and it proves to be a PITA and hassle. If I get more serious, the car is going on a trailer.
11-07-2014, 09:49 AM | #5 |
Drives: 2012 SS/RS Join Date: Jul 2013
11-07-2014, 01:40 PM | #6 | |
11-07-2014, 01:52 PM | #7 |
so they left the frame but without the hinge and covered it up with foam instead of the hard almost luggage floor like backing?
Typing fat fingered on my GS3...excuse any sfelling mitcakes
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars '94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A -- >> Some of my Projects My Fquick Page |
11-07-2014, 01:57 PM | #8 |
As far as I understand, they somehow reduced its weight by replacing its padding without removing from its chassis.
11-07-2014, 04:21 PM | #9 |
11-08-2014, 09:50 AM | #10 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm |
11-08-2014, 12:25 PM | #11 |
Good question. I am 6'0" and there is some compromise. I am not in a "clown car" but definitely up a few inches. I can handle it for the 160 mile trek to VIR.
11-10-2014, 10:11 AM | #12 |
update...front seat has much more travel if the tires are deflated...no surprise. Very livable for a long ride like this.
11-11-2014, 12:26 AM | #13 |
Drives: 2022 SS 1LE Join Date: Jul 2013
Trailer has worked great for me, except the one time that I broke at the track.
This is a small Lowe's trailer with a couple of truck tool boxes attached. Higher quality than the Harbor Freight trailer I borrowed from a friend once. IMG_5542 by solomontodd, on Flickr
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
11-11-2014, 10:27 AM | #14 |
Just getting away from 12" barely-bigger-than-wheelbarrow tires seems like a really good idea if you care much for your trailer's wheel bearings long term.
Norm |
Thread Tools | |
