JUICEDMOTORSPORTS
Old 07-05-2018, 04:11 PM   #1
saluki
Drives: 2014 Camaro SS
Central IL
Not sure how many of you are in central IL, but I will be at Havana Friday night.
http://www.centralillinoisdragway.com/
12016 North County Road 1650E, Havana, IL 62644
'14 2SS A6, CAI, 2" TSP Headers and tune
3.91's w/ trutrac, and BMR rear suspension.
Originally Posted by Gunmetal Speedster View Post
When in reality to you the only two jobs in the world where you get paid to guess and get it wrong every time is being a weatherman and working at Maryland Speed.
saluki is offline   Reply With Quote
Old 07-05-2018, 06:42 PM   #2
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
I usually go to Coles County. Haven't been to the Havana strip.
Lnch Mny is offline   Reply With Quote
Old 07-08-2018, 09:32 PM   #3
saluki
Well my 60 ft didn't drop to save its life but for my first time out in over a year I'm happy.
Best 60 ft I got was a 1.91(previous best was a 1.94) and this is with 3.91s, a full bmr suspension and MT 305 ET street R's. I feel that should have been low 1.8s to high 1.7's. 1/8th mile was 8.24 @87.7 mphwhich was 2.5 tenths better than the previous best.
Assuming I can get that 60 down it should easily be in the 7's.
Old 07-17-2018, 11:12 AM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
How are you doing your burnout? I think you can go 1.7's at least.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-25-2018, 09:13 PM   #5
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Havana, IL is like three hours away from me. I show up to Coles County in Charleston Illinois mostly it’s about an 1hr 20 minutes from me. Also Terre Haute Indiana. But I57 dragstrip just 45 min south of me. Slick Casner On Facebook IM me. Be fun racing more Camaro friends. The next Camaro fest is too long to wait.
Slickcas is offline   Reply With Quote
Old 07-26-2018, 01:20 PM   #6
saluki
just a short clean the tires was what I was doing that night.
I have been seeing some weird issues with TC/ABS. one night I had to pull fuses. the next time I went out the fuse pull didn't work and I had to put the fuses back in and use the button.
Old 07-26-2018, 08:32 PM   #7
Slickcas
Going to try and show up for this one never did flashlight start before.
Old 07-27-2018, 07:40 AM   #8
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
If the track prep sucks or the first 60 foot is like pebbles you need a bias ply to overcome that. I cut 1.7s on those at my home track in my 1LE, took my C6 a couple weeks ago (1.5x on QTP) and i could manage a 1.8 but at 4k rpm the tires would just let go.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, A FEW INTERNAL MODS (16 1.85 ROCKERS & PSI1511 SPRINGS AND A CRANK SCRAPER) AND E85 BASICALLY A MAX EFFORT STOCK HEADS STOCK CAM CAR
Best ET 10.58 @ 131.8 stock heads and stock cam
Best MPH 132
lazerlemonta is offline   Reply With Quote
Old 07-27-2018, 04:29 PM   #9
WoodBoss
"Old School"
WoodBoss's Avatar
Drives: 2010 2SS L99
Try using the button to disable nannies (hold down 8 seconds until both lights light up), do a 5 second burnout, stage, step on the brake hard and bring your rpms to 1600 then punch it hard on the last yellow while releasing the brake.
Back In The Saddle - Earley 2010 2SS IBM A6 #10244 Built - Roto-Fab CAI, Muffler/CAT Delete, 17" Mickey Thompson ET DRs, RDP Tune, ZL1 Fuel Pump, BW Stage II Ported TB, Speed Engineering 1-7/8" Longtubes, ZEX Nitrous 150HP Shot, Lingenfelter 160* Stat, NGK TR6IX Spark Plugs & Elite Catch Can, TCI Line Lock, JRE Trans Dipstick, BMR Trailing Arms & Toe Rods, 11.6 sec @ 120 mph - 1.59 sec 60' - 1/4 mile pass Check Out My Youtube Channel For 5th Gen Camaro Drag Racing & How To Mods https://www.youtube.com/channel/UCyG...GR9gDm6PO-27rg
WoodBoss is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
