Old 07-06-2018, 10:29 PM   #1
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6
Car feels slow
Did cam,long tubes no cats ,intake , full 3" outlaw catback
Did BMR toe and trail arms with there pro poly subframe bushings , BMR front and rear sway bar and there end links to go with them
305 45 18 Micky drag radials and race star wheels
Car just does not seem to have the power one would expect from a 450whp car , maybe the tires just hook to well to seem like it's lacking on power? Only done remote tuning with wideband so don't know if it's worth it to get dyno'ed for that extra power might pick up
davidscamaro is offline   Reply With Quote
Old 07-06-2018, 10:43 PM   #2
TheFlyingBananaSS
TheFlyingBananaSS's Avatar
Drives: 2013 Camaro 2SS
You may need a dyno tune.
TheFlyingBananaSS is offline   Reply With Quote
Old 07-06-2018, 10:54 PM   #3
zz430camaro
Drives: 67 camaro, 2015 1LE
My car is 485 rwhp and it is pretty quick feeling, when the tires hook up it halls ass. The better the tires the faster it feels, when the tires spin it slows the car down. Get it dyno'd and see where its at.
What cam is it?
zz430camaro is offline   Reply With Quote
Old 07-07-2018, 07:31 AM   #4
jc615
jc615's Avatar
Drives: Camaro and Sierra
Take it to track and see what it runs.
jc615 is offline   Reply With Quote
Old 07-07-2018, 10:54 AM   #5
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
My 442 definitely doesn't feel slow to me. You may need a dyno tune.
JerTM is offline   Reply With Quote
Old 07-07-2018, 12:28 PM   #6
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Check your canned tune .Without a proper tune you won't get the benefits from your mods. Did you data log it ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 07-07-2018, 12:50 PM   #7
Leo72793
Drives: 2011 2SS/RS
You mightve gotten bad gas. Could try syphening it out, and putting new fuel in.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers
•Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Morel Subwoofers
•Audio control LC-6.1200 6ch amp
•Helix DSP Pro
Leo72793 is offline   Reply With Quote
Old 07-15-2018, 03:04 AM   #8
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Take it to the track and see what it does....
2010 Cyber Gray Camaro 2SS RS A6
Circle D Specialties 3200-3400 Conveter
Cold Air Inductions CAI
JRE CAI Scoop + RotoFab Washer Bottle Relocation Kit
Kooks Jet Hot Ceramic Coated Signature Series 1-3/4 to 1-7/8 Stepped Headers
Kooks full true 3in exhaust
Trick Flow GenX 255's with Polished PAC .660's and Ti-retainers
Texas Speed VVT 3.2 cam kit w/DoD Delete
Texas Speed 1.72:1 Roller Rocker Arm Set
AEM X-Series OBDII Widebands
Fuel Injector Clinic ID850 Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Fuel Kit + E85
NGK Iridium IX spark plugs
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 07-15-2018, 11:53 AM   #9
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Needs a dyno tune... with a handheld tune or can tune u wont get the full benefit!
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2005 silverado 5.3
Long tubes, true dual bullets, aem intake , synergy tuned
2001 trans am
Lsx 408 ci rebuild in progress
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 07-15-2018, 09:41 PM   #10
CrazyRED
CrazyRED's Avatar
Drives: 2014 2SS RS 1LE
It's all relative. I have over 700hp and I think it feels slow. I want it to feel like my R1 when accelerating. Some people are easily impressed, others spend money and want to feel something so they say they do(perfect example is the vitesse throttle controller), and others are realistic.
In my opinion 500 hp in these heavy cars is nothing. My '99 Z28 went 13.1 stock with a cold air and longtubes at Gainesville Raceway back in the early 2000's and it felt way faster. I have many miles of 1/4 mile passes, every week for a couple years. I'm not impressed by gimmicks or numbers.
CrazyRED is offline   Reply With Quote
Old 07-16-2018, 08:18 AM   #11
John_C
LSx FTW!!!
John_C's Avatar
I think these newer cars numb the feeling a bit....
For instance, my 97 GT was a aluminum block PI swapped, 4r70w swapped to TR3550, full bolt-on car with 3:73's. 3,220lb (about 3,440lb with driver) car without driver.
The GT felt faster than my 2010 Camaro SS with Vararam and Corsa catback even though the SS was 4 tenths faster in the 1/4 mile. The Camaro was 4050lbs with me and 3/4 tank of fuel.
Now I'm closer to 500 whp and in the 11's but it still doesn't feel fast to me.
I don't think this 5th Gen will feel quick to me until I get in the 10's. LOL
HP Tuners VCM Suite
Old 07-16-2018, 07:04 PM   #12
CrazyRED
CrazyRED's Avatar
I think you're onto something as far the "feel" of the new cars. The power is certainly more manageable. I can get into an old '70's Malibu with a shift kit and some decent engine mods and it feels like I'm being shot to the moon. Then again, when you're a passenger it always feels faster too.
I will also add that the mechanical throttle on the F body Camaros of the late 90's and early 2000's made it feel faster as well. These drive by wire throttles drive me crazy.
Old 07-20-2018, 02:54 PM   #13
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
It is possible.....that your cam sacrifices punch off the line and at low RPMs in order to achieve that 450HP peak.
Also.....if those 305/48-18 tires are a bigger diameter than your OEM tires then you have LOST effective gear ratio.
Finally, if you have the auto transmission but still have the OEM torque converter.....then hell.....you could say that's 'strike three'.
In other words, you can get more peak power with a cam swap, but unless you have the necessary accessories/bolt-ons, your car can lose quite a bit of off-the-line performance. BTW....a dyno will help you to see if this is the case and to what extent.
Best of luck!
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci Solid Roller LT4
2014 Chevy SS --- 429ci LS3
KW Baraka is offline   Reply With Quote
