11-19-2021, 04:37 PM | #1 |
It don’t come easy.
Specialty license plates
I know there are a myriad of different “specialty” plates out there but, thought a state specific track plate was a nice idea. Got mine ordered, here in Wi for our local track, Road America. Cheap replacement for standard at $15 and you can also add personalization for an additional $15.
With the the black accents and wheels on my ride, this should work nicely. Anyone else have track specific plates out there?
11-19-2021, 07:09 PM | #2 |
Cool touch!!
11-19-2021, 07:13 PM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Time to register my car in Wisconsin
11-20-2021, 07:29 AM | #4 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Barber Museum tag for Ala
11-20-2021, 07:52 AM | #5 |
11-21-2021, 04:35 AM | #6 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
This is a subject that really "grinds my gears". I know some states require two plates and others just one. What bothers me is how "anal"(I'm so immature), about our CamaroGen5s, that depending what state you live in, it throws the whole color scheme off, like an eyesore. I think as long as the state and plate number are clear (maybe block font). I think it would be great to be able to choose two colors, to match. Make the plates with an electronic signal so the cop can just scan it into his computer if you're going over the speed limit, which none of us do.. My NJ plate is close to yellow but no where near the factory color. I know it might cost more but I was wondering if I'm overblowing this eyesore.
11-21-2021, 05:40 AM | #7 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
im not on board with being "scanned" to see how fast im going.
11-21-2021, 08:39 AM | #8 | |
Drives: 2012 Camaro SS Join Date: Dec 2019
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
11-21-2021, 08:52 PM | #9 |
11-22-2021, 07:48 PM | #10 |
It don’t come easy.
Now don’t that just perrrty?!
11-22-2021, 11:40 PM | #11 |
Looks Great!!!! That's what I'm talking about. The states should let us at least pick the colors and letters of our plates. This looks great!!
11-24-2021, 11:08 AM | #12 |
Drives: 2012 2ss stick. Boosted 45th! Join Date: Oct 2020
So how long are you all waiting to get your plates? I ordered this one in July (2021). At the time it stated 8-12 weeks lead time. I go back now and it says 24-36 weeks! WTF!
45th Anniversary.stick. Boosted!
11-24-2021, 04:45 PM | #13 |
It don’t come easy.
Got mine in approximately 3 weeks from the time I ordered it. I was happily surprised.
11-27-2021, 03:41 AM | #14 |
Drives: 2010 Camaro SS Join Date: Feb 2018
My plate just says "THT GUY"
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
Thread Tools | |
