06-21-2015, 11:17 AM | #1 |
Drives: 2012 M6 Victory Red Camaro ZL1 Join Date: May 2014
Twin Turbo Camaro Issues.....Help!!!
Hey guys,
I currently running the IPS twin turbo kit. I got the kit installed at around 7k miles last June. I have had little to no problems and the car is my daily driver. I just recently hit 25,000 on the odometer, and everything seemed to be fine with the car. Recently the CEL came on, and I went ahead and scanned to see what was up and I got both P0171 and P0174 (too lean on both banks). I thought it was just the gas, so I emptied the tank, refueled, and reset the code, and drove it a week without issues. Then two days ago the CEL popped back on and the same codes popped up. Except this time the car was idling from 500 rpms and would bounce to 200 rpms, and on occasions would stall out. Yesterday, I took it out again, except this time the car struggles to stay alive (chugging horribly, low rpms when driving, stalling out almost every stop), it is also shifting terribly (very jerky), the service stabilitrak also comes on and off, and the check engine light will blink on occasions. To make matter worse, when I popped the hood there is a knocking noise. Your insights and knowledge are always appreciated Thanks |
06-21-2015, 11:18 AM | #2 | |
06-21-2015, 01:52 PM | #3 |
That almost sounds like a rod knock . Hope I'm wrong . I'd do an oil change and check for metal . Check and see if you can bring it in under warranty .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
06-21-2015, 03:03 PM | #4 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
Man that doesn't sound good, maybe pull the mass air flow and check/clean it for the codes and look for any way extra air is getting in after the maf.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
06-21-2015, 03:13 PM | #5 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
There is absolutely NO warranty on the engine after being boosted by a pair of turbos.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
06-21-2015, 04:09 PM | #6 |
Bro I'm running this kit I would stop driving it now and find out the issue mine did the same thing for a few months I had told the shop about it when I went to get a boost controller on and they didn't seem to think it was vital when they scanned when I brought it to another shop , they said imy 3rd cylinder was misfiring after I got it about 2 months ago I had 3 cylinders fail out had to replace the engine it would idle from roughly 550 then do as you say drop low then kill or come back up. It was only aince here and there at first but then the stalling increased making the car very unsafe I weas experiencing both of those codes aswell before the engine went the p0171 one was showing after I installed my vitesse controller before I even had the kit though and was putting me in limp mode . Somthing I would check is the sparkplug gaping the shop that did my install didn't follow instructions on that part so it can't burn off all the gas that is released in some cases they said vehicles wouldn't even start at all, I believe they said the correct gap is 2200. Hope you the best , park it to be safe would hate for the same to happen to you. The first shop I had it in before I brought it to a dealership seemed to thing it was acting like it had sucked something up and blew a whole through the piston aswell
06-21-2015, 05:53 PM | #7 |
06-21-2015, 07:11 PM | #8 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Try new plugs- NGK LTR7IX-11 gapped to .032 or Denso Iridium plug: 5340 = ITV22
.031" (0.8mm) Gap out of the box. 18K miles is all you're gonna get from a set with twin turbo's. |
06-21-2015, 07:54 PM | #9 |
Hmm.. Yeah plugs would prob be a good idea gapped to .026-.028 but I don't think that's causing your knock noise. That doesn't sound good, good thing used motors are so cheap. I've only put 2500 miles on my kit but I'd be happy if my motor makes it as long as yours. I run this thing hard. What oil have you been using and how often do you change it? Brian told me to use Rotella 5w40 and to change it at least every 2,000 miles.
06-21-2015, 08:06 PM | #10 | |
06-21-2015, 09:20 PM | #11 |
Okay so a quick update tomorrow I will be doing an oil change, a spark plug change, and also will be using oil injector cleaner, and oil treatment. I turned the car on again recently and there was no knocking, and I ran the scanner and the P0300 (random misfire) came up. I'll keep you guys updated, and again thanks for the insights
06-22-2015, 02:22 AM | #12 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Why? How is this GMs fault, you're the one who chose to turbo the car
06-22-2015, 02:34 AM | #13 |
Drives: 2015 Red Hot SS/RS M6 Join Date: Sep 2012
Run a magnet through that oil when you get it out of the car. Cut your oil filter open too.
If you see metal shavings, it's bad. If you don't, do a dance. |
06-22-2015, 09:24 AM | #14 |
Drives: 2015 LFX Auto Join Date: Apr 2015
Check oil level every 1k miles or less? What is the level before you drain for the change?
You do not want to run these low on oil...if the pick up sucks air even briefly the tensioners lose tension and it can jump timing easily. Not to mention take out bearings in short order. |
