08-08-2018, 06:38 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Power steering fluid
If I'm correct the early 2010 camaros used ATF for the power steering instead of the usual prestone power steering ??
08-08-2018, 08:54 PM | #2 | |
Drives: Miss Con Ception Join Date: Aug 2016
From the 2010 owner's manual:
2011 1SS/RS LS3 CGM
09-12-2018, 11:52 AM | #3 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
Does my 2011 L99 also use ATF?
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
09-12-2018, 08:13 PM | #4 | |
No.
2011 1SS/RS LS3 CGM
09-13-2018, 06:18 AM | #5 |
Is there a diy for flushing the old fluid out?
Thanks. Bill
10-23-2018, 01:04 PM | #6 |
Psycho on day pass
Drives: 2010 yellow 1ss m6 -GM tech Join Date: Apr 2009
The only difference between ATF and PS fluid is the boiling point and PSI rating.
PS fluid has a higher boiling point and wont degrade as fast compared to ATF. ATF is roughly 1200 PSI boiling point and PS fluid is roughly 1600 PSi. |
10-23-2018, 03:33 PM | #7 | |
Thanks. Bill
11-12-2018, 03:23 PM | #8 |
USA-1
To jump in on this, I saw some full synthetic power steering fluid made for American vehicles at Walmart, is that stuff safe to use?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
11-12-2018, 03:55 PM | #9 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
The part number for the GM fluid has changed twice since the original posted part number of 89020661. It is now 19329448. For how much longer is anyone's guess. List price from GM is $12.52 as of today. You can find it on fleabay for around 11 bucks shipped give or take.
As far as buying the synthetic stuff, it should be ok as long as it doesn't have some sort of stop leak crap in it, or some cheesy cheap store brand. Buy a name brand and you know it'll be quality. It may say it's compatible with the non-synthetic on the bottle. Most are. It's your car and your money, but for an extra buck, I'd go with a brand name fluid if not the GM stuff. If it's Prestone full syn for AMERICAN CARS (has the BLUE stripe on the bottom of the label), it claims to be mixable with factory fill stuff, and it's about the same price point as the GM stuff.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-12-2018, 04:48 PM | #10 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Is there supposed to be a certain mileage where you need to flush and refill the powered steering fluid?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
11-12-2018, 05:23 PM | #11 | |
Older Than Dirt
Keeping check on the level and topped off and if it's a little darker it's ok. I'd say as long as it's not contaminated, you should be ok.
11-12-2018, 05:31 PM | #12 | |
Yeah. I checked my fluid level a couple weeks ago just out of curiosity and it’s still fine. No leaks either.
11-04-2019, 03:30 PM | #13 |
Drives: '10 Camaro SS Join Date: May 2019
Hi guys, i know this is a old thread. but i have a question. How much i need fluid for the power steering fluid change? Can i use that oil?
https://www.amazon.com/Motul-Automat...2902968&sr=8-1 My car is 2010 camaro ss. Thank you. |
11-04-2019, 07:31 PM | #14 |
USA-1
1 bottle would be plenty, and yes, you can use that.
