05-28-2019, 07:33 PM | #1 |
Customized my new BMR adjustable LCA’s
Took my suspension to the next dimension after modifying my new adjustable LCA’s. To anyone who wants to have dual dampening coilovers and the adjustable lower control arms, it is doable but you need to modify the control arms if you are lowering as well.
Here are some pictures of some rear suspension upgrades and the modifications I did on the new LCA’s. This requires knowledge and experience of fabrication including welding to do this correctly and at the high cost of adjustable LCA’s, I suggest you go to a fab shop if you can not cut, grind, weld and properly paint metal.
Car mods: never enough!
05-28-2019, 07:35 PM | #2 |
05-28-2019, 07:37 PM | #3 |
05-28-2019, 07:42 PM | #4 |
If you lower your rear dual coilovers you will hit the braided fluid reservoir line and it simply won’t work if you go lower than say stock height. What’s the point in that right.. nobody buys dual coilovers to stay stock height LOL. Here’s a fix...
05-28-2019, 07:46 PM | #5 |
05-28-2019, 07:47 PM | #6 |
05-28-2019, 07:49 PM | #7 |
05-28-2019, 07:52 PM | #8 |
Test fitting reservoir line clearances. Works great and plenty of clearances now at full lowered coilover.
05-28-2019, 07:57 PM | #9 |
Prep for welding added support brackets etc.
05-28-2019, 08:05 PM | #10 |
Shaping and grinding after welding bracket supports
05-28-2019, 08:07 PM | #11 |
05-28-2019, 08:12 PM | #12 |
Complete and now fully adjustable coilovers, LCA’s, toe rods and trailing arms.
05-29-2019, 02:26 AM | #13 |
Drives: 2011 2SS Join Date: Mar 2015
What about rotating the canister 180 degrees so the hose is on the opposite side with more clearance??
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
05-29-2019, 07:04 AM | #14 | |
BMR built these things great and solid. After cutting my openings I probably did not need to add the extra side supports but wanted a piece of mind by being certain. After adding the extra side supports following cutting the openings these things are so strong you could use them on a monster truck..LOL.
