06-12-2017, 03:07 PM | #1 |
Liv'n The Dream!
F1 SUPERCARS ON SALE! $144.08 PER!
Originally I wanted to buy the Firestone FireHawk Indy 500's but they're out of stock and none planned to be made for a while. Anyway,….
TireRack.com called me to let me know it was going to be a long time before they were going to get anymore and would I like to get something else instead. I asked the guy the normal questions and then asked…What else do you have around the same price? Long story trimmed up a bit…. They have enough of these babies for MORE THAN 10 complete sets of OEM Goodyear F1 Supercars which they are trying to move for $144.08 each! The “catch” if you will, is these tires are nearly 5 years old. I’ve done my homework on this and even Goodyear says that’s not an issue. To boil that point down a little further, a brand new tire that’s never been used, stored in a temp controlled environment, and not exposed to direct sunlight will last nearly indefinitely. I’m sure there’s about 100 or more of you out there that will swear on their dead grandmother’s grave that it’s not the truth, they’re lying, just trying to sell their old junk. To that I say…Blah blah blah. If you’re old enough to drive you’ve probably heard of the Ford/Firestone case and that alone should tell you that a big company like TireRack is not going to sell tires that will likely put them out of business. So I bought them. I’ve got four tires with shipping and heat treating service added delivered to my local Firestone dealer for installation for $725.60! But don’t stop there folks! There’s an $80 mail in rebate that takes that stupid low price down to $645.6 for a full set of G2’s (plus install) The guy that helped me out was very cool and you can go through him if you like. Todd Galbreath can be reached at: 1-800-428-8355 Ext 4673 Take it or leave it. I’ve got temp controlled garage so I may just buy a second set! Good luck!
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
06-12-2017, 03:19 PM | #2 |
Liv'n The Dream!
Mind blown! I just emailed my wife telling her I was thinking we should get a second set and she said go for it!
You could knock me over with a feather right now. LOL
06-12-2017, 03:56 PM | #3 |
Drives: 2015 2SS 1LE Join Date: Dec 2011
Is it worth heat cycling the tires for someone that does not track their car? Only aggressive street driving.
06-12-2017, 04:09 PM | #4 |
Liv'n The Dream!
I would say so. Should help with longevity.
06-12-2017, 04:18 PM | #5 |
Tire Rack recommended not heat cycling them for street use so I bought them without the heat cycle. $672.72 shipped before the rebate.
Rights: https://www.tirerack.com/tires/tires...OLD&tab=Survey Lefts: https://www.tirerack.com/tires/tires...OLD&tab=Survey If you want them heat cycled you have to call them and if not just order them from the links. |
06-12-2017, 04:34 PM | #6 |
KaBoom1701
Of course.....right after I bought a set or rear G2's.....lol
Mods:
06-12-2017, 05:41 PM | #7 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Just tried. Looks like they only have left side and they are up to $199.95 each.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
06-12-2017, 05:45 PM | #8 | |
Liv'n The Dream!
He told me they had plenty of them. "...More than enough for 10 + cars."
06-12-2017, 05:46 PM | #9 | |
Liv'n The Dream!
06-12-2017, 06:56 PM | #10 |
Drives: 2012 2SS RS Join Date: May 2012
Amazing deal, thanks for the heads up. Just bought a set.
06-12-2017, 07:39 PM | #11 | |
If you want them heat cycled you have to call them as you can not do it from the web links. |
06-12-2017, 07:51 PM | #12 |
Liv'n The Dream!
Not a problem. If I could have afforded it I would've bought several sets myself.
Still got the best wife on the planet! Told me to get a second set.
06-12-2017, 09:53 PM | #13 |
Drives: 2013 1LE RS 1SS Join Date: Apr 2009
I bought a set of the 305-35-20 left over from 2012 cheap from them last year last as good or better than the stock 285/35/20
06-12-2017, 09:54 PM | #14 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
FYI, those are not the same F1's that came on our cars, that is a different load rating (92Y vs 100Y)
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
