08-01-2020, 12:19 PM | #1 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Aftermarket starter
Who has the best aftermarket starter for a ls3? Having starting issues on the stock starter and want something made for a high hp na car
08-01-2020, 02:45 PM | #2 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
NEW OEM
New OEM or have yours rebuilt by a quality rebuilder. Keep the heat away from it and you will be fine . Check your flywheel or flex plate to make sure its not your problem .
OLD GUY FLYING FAST AND LOW
08-02-2020, 10:26 PM | #3 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
curious, whats the issue?
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
08-02-2020, 10:34 PM | #4 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i have amazon prime so this is free shipping
O.E FOR 95 BUCKS IS HARD TO BEAT https://www.amazon.com/ACDelco-12617.../dp/B0031IBRZA |
08-02-2020, 11:03 PM | #5 |
Oem cool and all but I kinda want to upgrade just seeing what everyone thinks is the best for a modded motor heads,cam,intake,higher compression. Issue is multiple hot starts, the car struggles to start in about 96 degree weather
08-03-2020, 06:17 AM | #6 |
08-03-2020, 06:19 AM | #7 |
Do all of those mods and adjustments that's mentioned in that thread and it should cure your issue.
08-03-2020, 09:56 AM | #8 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I think someone on the 1LE.R page on FB did a Gen6 starter supposed to have a lot more torque.
This is from Zach at Katech. https://www.camaro5.com/forums/showt...=575984&page=3
Orange Krush II
08-03-2020, 10:58 AM | #9 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Does the engine turn over slow, or does it crank quickly several times and not start? I'm in Florida, plenty of heat here.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
08-03-2020, 07:49 PM | #10 |
or
Summit RacingSummit Racing Verified Purchase CVS-5414 Installed this on my 2010 Camaro Ss! This finally fixed my hot start problems! I can now take my car anywhere and start it up again the moment I turn it off instead of waiting 30minutes to an hour with the OEM starter. If your Camaro is upgraded and having hot start problems, I highly recommend the CVR Protroque starter! https://www.summitracing.com/parts/cvs-5414 |
08-03-2020, 09:12 PM | #11 |
True that on the tune my tune rn is not ideal bc of the hot weather and humidity it’s really rich atm and I have a thinner head gasket I think a felpro 0.048”
08-03-2020, 09:25 PM | #12 |
Anyone like the power master starters?
