03-05-2012, 04:07 AM | #1 |
Drives: 2010 2SS/RS Victory Red Join Date: Mar 2011
Decal Removal
How hard is it to remove factory or aftermarket hood stripes and decals? What affect might a removal have on the underlying paint?
Thanks.
21 years of owning Camaros. Finally got a 5th Generation. |
03-05-2012, 04:24 AM | #2 |
Hood stripes are vinyl so you should be able to peel them off. Migh have some adhesive residue left behind, but that should be easy to remove too. Your paint will be fine.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
03-05-2012, 04:46 AM | #3 |
Dave
Drives: 2011 Camaro SS - Black/CGM Stripes Join Date: Feb 2012
Dealer told me that hood stripes can be easily removed if done within the first 60 days of their application. After that time period, some discolorization of the underlying paint could occur, depending upon whether or not the vehicle was subject to long periods of direct sunlight.
03-05-2012, 06:23 AM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Easy to remove. Let car sit in the sunlight for a few hours. Then hit it with a heat gun, if you're experienced with a heat gun. If not experienced, then use a hair dryer on high. The hair dryer will take longer but less chance of damaging anything. Then slowly peel it off.
Only one way to find out what the paint looks like. Every paint, every pigment, every car's UV exposure... is different. If it's out of whack, just put new stripes back in the exact same spot. You can take them off a lot longer than 60 days. I've taken vinyl off years later and it peeled right off with heat and the paint was perfect. A little bit of goo gone and alcohol will clean the residue right up. If the car is mainly garaged, I'd bet the paint will be perfectly fine. |
03-05-2012, 08:37 AM | #5 |
Ok. Thanks everyone.
Thread Tools | |
Similar Threads | ||||
2012 transformers front bumper decal help | Transformers | Cosmetics and Lighting Modification Discussions | 2 | 02-16-2012 07:16 AM |
Finally available: matching front Bowtie overlay decal at PFYC.com | PFYC | Exterior Parts & Accessories | 0 | 08-04-2010 08:19 AM |
dealer decal removal | hfdff | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 3 | 05-17-2010 08:03 PM |
HooD Artwork Painted or decal? | GraysonPeace | Cosmetics and Lighting Modification Discussions | 5 | 03-07-2010 12:00 AM |
