03-19-2020, 04:26 AM | #1 |
Weird/rough idle 2010 2SS
Mechanicmike90's Avatar
Drives: Chevy camaro Join Date: Mar 2020 Location: VA Posts: 2 View My Garage iTrader Rating: 0 reviews Exclamation Weird/rough idle I'm new to the forums here and a new camaro owner at that. But here's my issue. I have a 2010 SS 6 speed and I'm having some odd idle issues. Only mods on the car are CAI and borla catback. I do not have any check engine lights on or pending codes when scanned with a professional snap-on or similar scan tool. While running the live data stream you can see the misfire counter go up but again no specific code for a certain cylinder. I recently replaced the spark plugs with OE ACdelco from the dealer(no change). I run 93 octane whenever I fill up. I have checked and cleaned the throttle body already. I've picked the brains of all my master technician friends some with 20+ years in the field and we cant seem to find an issue. Any ideas on where else to look or things to try would be a great help. Mike |
03-19-2020, 09:41 AM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
The wires would be my next thing to check.
2014 2SS/RS LS3/M6
03-19-2020, 01:15 PM | #3 |
Psycho on day pass
Drives: 2010 yellow 1ss m6 -GM tech Join Date: Apr 2009
Sometimes an engine will count misfires that could be related to many things.
Just because you use 93 octane doesnt mean there isnt a slight contamination in it. If there was an issue, it would set a P0300 code for multiple misfires detected down to a specific cylinder code. If an engine was meant to run perfect in a perfect world, there would be no need for a knock sensor. Dont sweat it. Scan another vehicle and watch the misfire counter on the roadtest. Even a blips of the throttle might show a slight misfire. Normal. |
03-19-2020, 02:27 PM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
These cars out of the factory have idle fluctuation. It does have a slight cam in it. Many mistake this for an issue. If you are able to post a video...might be able to help a bit more.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-19-2020, 09:36 PM | #5 |
03-20-2020, 06:22 PM | #6 | |
Drives: 15 1SS 1LE Join Date: Nov 2019
At idle and cruising at 75 on interstate I get 0 misfires. |
03-23-2020, 01:43 PM | #7 | |
Psycho on day pass
Blipping the throttle to down shift and applying acceleration from a coast could cause minor and insignificant misfires. The counter will count and like you said 20-30 in an hour??????? Normal. During idle and cruising you see 0 misfires. That tells me there is nothing wrong with your engine. If there was, it would count constantly. You have to allow error for incomplete combustion, quality of fuel, performance upgrades that hamper a tune, carbon build up, blow by, air quality, dirty injectors etc. When we see a CONSTANT misfire count or large misfire numbers in many cylinders due to shorting ignition or bad injectors, then its a concern. Obvious engine damage causing a misfire like a worn cam, etc. will also count huge misfire counts. To have a slight count like you mention(20-30 an hour) is no need for concern especially if you have no SES light on. New era sensors are very sensitive and will count the slightest stumble. |
03-23-2020, 06:15 PM | #8 | |
03-23-2020, 06:21 PM | #9 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Might be normal like stated or maybe change the wires next. Mine were the original from 2012 and when I changed them this year 2 of them were dry rotted and broke apart.
Also perform a fuse pull
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
