JDP Motorsports
Old 09-23-2018, 10:09 AM   #1
Rem0v3r
Drives: 2013 ss2 vert l99
Dyno error?
I'm trying to find some reason or logic for what happened the other night so hopefully someone can shed some light..
I went to a car show where they had a mobile dynojet dyno.. my car is an l99 twin rear mount turbo.. 4400lb vert pushing 7psi of boost at 11.0 ish afr around 14 degrees final timing.. the car has never been on a dyno
I destroy the newer corvettes all day long, it's not even close..
They said 385rwhp... to me that doesn't make sense.
What are the options here?
Rem0v3r is offline   Reply With Quote
Old 09-23-2018, 10:17 AM   #2
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
means the dyno is off.
ZL1 10 spokes,LS3 Conversion,ECS Supercharger, BTR Trunion Upgrade, B&M Tranny Cooler, Vigilante 3600 Triple Disc TC,Katech Ported Heads, Rod Mod Intake, Comp Stage 3 cam,ATI Super Dampner, Pfadt Springs, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 rear diff, SW Long Tubes no cats,Bo White Throttle Body, Dr Phil Tune,GHL Cat back, Elite Catch Can, 20% Tint all around
gm2376 is online now   Reply With Quote
Old 09-23-2018, 11:05 AM   #3
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
way off
Current: 2015 ZL1 M6, Rotofab, VMAX Throttle body, 2.55 Upper/8.86 Lower Pulleys, ID1050X, 1 7/8" Headers, 614rwhp/616rwtq
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 09-23-2018, 12:32 PM   #4
HDRDTD
What were other cars measuring at? Were they way off as well ??
Did the dyno chart have a reasonable looking curve shape for both HP and Tq ?
Old 09-23-2018, 01:08 PM   #5
Rem0v3r
I didn't stick around.. I was the first car up there, after that I left to go cry in my beer haha.. they're supposed to be emailing the results to me.. I'll post when I get them.
Old 09-23-2018, 01:08 PM   #6
Rem0v3r
They did tell me they were only measuring horsepower.. not sure how it all works
Old 09-23-2018, 03:49 PM   #7
HDRDTD
Does it matter what gear the car was in? If so, perhaps they made a mistake and it was in the wrong gear?
Perhaps they discovered a mistake with your run afterwards and corrected it for the rest of the runs?
Maybe they made a mistake and the results they gave you were for the last car that had run on the dyno the last time they used it.
Regardless, if they told you the results then and there, I'd ask for another run to verify the results. Most dyno runs include two runs back to back. Then they report the better of the two.
Old 09-23-2018, 05:37 PM   #8
Rem0v3r
I paid for 2 runs, I ran 4 back to back.. they wanted me to do a 5th but I didn't want to beat the shit out of my car... the numbers were not changing and I didn't want to flog a dead horse.
Old 09-23-2018, 06:43 PM   #9
13SSCamaro
13SSCamaro's Avatar
Drives: 2013 Camaro SS
Were your tires spinning on the dyno?
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, 850 injectors,ZL1 fuel pump, Flex sensor and E-85 512rwhp/462rwtq
13SSCamaro is offline   Reply With Quote
Old 09-23-2018, 06:45 PM   #10
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Were you operating the car..... to what RPM did you make your pulls....and in what gear... Rear mount, (trunk area) turbos take a while to spool, and if you shut down early then you might not have ever gotten into the sweet spot....
or....
Their junk was off....Them having 4 pulls performed and wanting a 5th tells me their junk was not calibrated....
Old 09-23-2018, 07:10 PM   #11
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Ok...
So, (RPMxTorque) / 5252 =HP
You gave us a HP of 385. Working this backwards and making some assumptions.... Here is your torque...
HP x 5252 / RPM = Torque
385 x 5252 / 4000 = T
2022020 / 4000 = 505
2022020 / 4500 = 449
2022020 / 5000 = 404
2022020 / 5500 = 367
2022020 / 6000 = 337
2022020 / 6500 = 311
Without a dyno printout or screenshot showing actual references this is a best guess. With MPH and max torque on a graph, it could be worked out provided your trans and diff gears are factory, or these are known numbers....
My best guess is their stuff wasn't working correctly.... I say this because with rear mount turbos, you won't make max torque at 4000 rpm.... I'm thinking your max torque would be in the 5000 - 5500 rpm range, but I might be very wrong.... We need more information...
Having said all that, if you are smoking newer Vettes easily, their numbers were way off....
Old 09-25-2018, 08:35 AM   #12
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Yes your into a dyno that's worthless but for some stupid bragging rights well there you go; all HP numbers are figured off the torque and almost all dynojets are non load bearing so they usually if not made just right by the operator can inflate numbers. Every dyno has to have correction factors correlating the thing due to temperature humidity and elevation also and who knows what that was or what the sheet would have looked like …….and 11 AFR is really not so good.... Stoich being 14.7 most go rich to about 12.7ish for WOT.... how the numbers so messed up?????/ most likely a combination of crap....and 7 psi not much you don't mention what other mods.....
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 09-25-2018, 04:32 PM   #13
Rem0v3r
Twin turbo gt35s 1000c injectors zl1 fuel pump cats removed, stock everything else. 12.7 is rich for na, boosted apps need richer... running on 93 pump gas.
Old 09-26-2018, 12:25 AM   #14
silversleeper
Some ol' dude
silversleeper's Avatar
Drives: '13 ZL1
Ok...
I was reading Hammdo's thread trying to figure out parts of my tune and you said you dislike math and here you go ! Did you stay at a Holiday Inn Express last night
silversleeper is offline   Reply With Quote
