Old 02-10-2022, 06:32 PM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Offroad Vs Non?
I am looking at Texas Speed for headers for my 2012 2ss ls3. I was wondering which ones to go for I just want straightpiped from the headers back. I was confused on what the offroad headers are and I dont want them not to fit. I also dont know if I should go with 1 7/8 inch or 2 inch. The 2 inch seem a lot more expensive. Sorry if I sound dumb I truly don't know and I am trying to learn.
jesse121pm is offline   Reply With Quote
Old 02-10-2022, 07:24 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Offroad referring to headers/cats generally means that they're not meant for the street because they may or may not be street legal depending on the state/province (emissions-related). If your state/province doesn't require your car to have cats - or you just don't care about getting a hefty fine - go for it!
KillboyPowerhead is offline   Reply With Quote
Old 02-10-2022, 07:42 PM   #3
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
racin stuff
ADVMax is offline   Reply With Quote
Old 02-11-2022, 08:26 AM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
the true meaning of parts that are labeled "for off-road use only" is to cover any liability to the company if ANY damage is caused because of your use on a street car.
exhaust, headers
