Cold Air Inductions
Old 05-08-2014, 08:02 PM   #1
Joshua nuzzo
Joshua nuzzo's Avatar
Drives: Supercharged 2011 camaro ss vert
How hot should my whipple be???
I've had the charger on the car just over a year now. It was 95 here today and I went for a ride after work. after I popped the hood and went to lay my hand on top and the whipple was hot! Not hot enough to burn me but I couldn't leave my hand up there but a sec. Seems last summer it run very cool and I could lay my hand on it right after a 1/4 blast or a good hard drive around town. I do run 100% meth that kicks on at 4lbs of boost. If it's not normal what should I be looking for.. Thanks for your time
Joshua nuzzo is offline   Reply With Quote
Old 05-08-2014, 08:58 PM   #2
ayousef
ayousef's Avatar
Drives: 2013 ZL1
its normal, the blower is sitting on a hot engine, what did you expect
Right and this has nothing to do with meth, meth controls intake air temp rise from boosting the air and helps very little with heatsoak from the blower sitting over a hot motor. Get an intake air temp gauge, look at your coolant temp, oil temps and so on if everything is in check ur good, putting your hand on the blower is an indication of nothing.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 05-08-2014, 09:11 PM   #3
Joshua nuzzo
Lol ok guess I'm just tripping and been a little freaked since the crap 6l80 is going out and just spent a good amount on a 4l and parts. Just didn't remember it ever being that hot last summer and after taking it to the drag strip 2 months ago popped my hood after every pull and always check the heat just never got that hot. I will check my temps and thx for the feed back
Old 05-08-2014, 09:14 PM   #4
ayousef
ayousef's Avatar
Drives: 2013 ZL1
seriously though you shouldn't worry about the blower being hot, even a bone stock car will be hot to the touch especially if you have an aluminum cold air intake or a sheetmetal intake then you're in burning category
Old 05-09-2014, 06:31 AM   #5
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
Heat rises !! Your blower is a heat sink..
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 05-09-2014, 09:55 AM   #6
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Yeah had mine 2.5 years and running it hard at the track you can't put your hand on it from the heat. Its ok
Ho how did the 4L go???
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
